Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-17-2002, 03:53 PM
sakes sakes is offline
Send a message via AIM to sakes
this is gonna make me look stupid but...
ok what i want to know is how does a turbo work? does it have to match up with the block or the head? what is turbo lag, and what would i be better off doing (amount of boost and hp per dollar) turbo on a b20 block and b16 head or a supercharger?
SAKEONER
89 crx unmodded as of now
saving for a b20 swap!!!!
eventual mods...
b16a swap w/tranny
clutch masters clutch,TC,flywheel
b16 block replaced by b20 block
arias pistons and rings
skunk 2 cams
skunk 2 cam gears
skunk 2 pulleys
mugen ecu
msd ignition and wires
venom fuel pump
venom fuel regulator
venom 400 modual
venom injectors
aem cai
dc or comptech 4-1 stainless header
hks or comptech cat back
aem fuel rails
holley throttle body
skunk 2 adjustible coilovers and shocks
dc sport upper strut tower bars
aem big break kit
oz f1 cup 17"rims wrapped in yokohama rubber
and one day....vortech supercharger and a nitrous kit......
what can i say....im a dreamer....one day!!!!
it will be mine...oh yes it will be mine!!!
isn't it beautiful!!
Old 02-17-2002, 05:08 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
www.howstuffworks.com
read about it.
Old 02-17-2002, 05:09 PM
drift's Avatar
and take that stupid dreamer list off your sig. it's not only long and obnoxious, but it's a bunch of stuff you dont even have.
Old 02-17-2002, 05:18 PM
SPEEDY SPEEDY is offline
im no "pro" or whatever but i can just tell you what i know..anyone else feel free to add..A Turbo works buy running off exhaust gases and uses that to make power . It has to Mach up with the block. Turbo's match up with the block and superchargers match up with the head. Turbo lag is the time the Turbo takes to spool up boost. Superchargers make boost from the moment you step on the gas because it runs of the air coming through the intake. And if you're wondering what your better off doing..it all depends on your personal preferance. If you want a daily driver with a lil kick you can go with a Supercharger or Turbo (Stage 1). Turbo's require more attention towards maintenance where Superchargers you just do your regular oil changes. If your going to use your car mostly for racing then go with a turbo and upgrade it. Hope this helps you out bro..again anyone else add or comment..woudlnt wanna give anyone misleading info..Peace
00 Civic coupe..C-G-P
Greddy Turbo Kit
Apexi N1 Exhaust
Black Housed w/ ion Lense headlights
Carbon Fiber Euro Altezzas
Wings West Type W kit
Universal Commando
White 16" Motegi MR7's w/Toyos
Eibach Prokit w/ Tokico Blues
Old 02-18-2002, 12:29 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
turbo is run of exhaust gases which spins a turbin which compresses the intake flow, so it bolts to a sopecial manifold, a SC, does the same thing, it compresses the intake air,m excep[t it doesnt run off he intake air, it runs off of the engine buy usoing a pulley, whihc is why it is instantaneous, the ngine spins, the SC does too, a turbo takles time to spool up because ayt foirst the exhaust gases dont flow fast enough to get it spinning goods, especialy wiht a larger turbo, but when the rpms go up theres more flow and the turbo is spooled
Im not an expert either so others can add to mine
Old 02-19-2002, 06:33 PM
so let me get this straight....pretty muchly your sayin that a supercharger gives you instantanious power, a turbo gives you more power but takes more time to kick in...ie turbo lag.
SAKEONER
eventual mods...
b16a swap w/tranny
skunk 2 cams
skunk 2 cam gears
skunk 2 pulleys
mugen ecu
venom fuel pump
venom 400 modual
venom injectors
aem cai
aem fuel rails
aem big break kit
Old 02-19-2002, 07:03 PM
Yup..the supercharger gives you full boost from idle throughout the rpm band...and Turbo usually reaches full boost around 2500 depending on your setup..
Greddy Turbo Kit
Apexi N1 Exhaust
Universal Commando
Old 02-19-2002, 07:44 PM
94tegRS's Avatar
a SC doesnt give full boost at all times though i dont think, because when thre engine is only at like 1500RPM, I guess it could give some bost but i dobnt think that you could get 11 psi or so at idle, maybe, but also on the JRSC, I think it only works when on the throtle hard becauise of some vaccum thing that bypasses the boostwhen cruisuing
Old 02-19-2002, 09:01 PM
drift's Avatar
that is incorrect. full boost isnt reached until the motor is revving at the supercharger's highest specific output.
but it does create boost lower in the rpm band, just not full boost from the start.
Old 02-20-2002, 12:30 AM
94tegRS's Avatar
thought so, and also you cant get near the boost off a SC that you can off a turbo, right?
also can you SC and turbo?
so oyu can have the SC to give you some power off the line and then have the turbo spool up later and give more boost, or like take over and give you a tonna boost.
is there any SC you can turn on and off with a switch, never seen em, cept for a movie and you know how that goes
