Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 10-07-2004, 09:58 PM
billclinton's Avatar
billclinton billclinton is offline
300hp with rb20 easy?
Hello, I own a 1989 240SX with the KA24E. Timing chain snapped and now the engines shot. I can get an RB20 for a little bit less then an sr20det and was wondering if the rb 20 is capable of 300hp with basic mods such as intake, exhaust, fmic, and boost controller. Im not looking to go all out on this motor and my money is limited but if I can acheive 300hp with those modifications I will be purchasing this engine. (rather go rb20 then sr because it has a timing belt, and i no longer trust chains, like the sr20)
shinrekka 1 : i think the carburater needed to be rebuilt and were gonna drop the gas tank
NoLlieSkillz : its called
NoLlieSkillz : neutral drop at redline
Old 10-09-2004, 02:21 AM
Neil_se's Avatar
Neil_se Neil_se is offline
Re: 300hp with rb20 easy?
300 bhp or 300rwhp? Either is not hard. I'm making 300rwhp with hks2530, full exhaust, POD, fmic, fuel pump, SAFC and 15.5psi.
Black rb20det 180sx|HKS gt2530|Greddy fmic|Apexi N1 Exhaust|K&N pod|Apexi BOV|GTR fuel pump|SAFC|HKS FCD|Volk GTU rims
Old 10-09-2004, 03:02 PM
nismo_power's Avatar
nismo_power nismo_power is offline
Re: Re: 300hp with rb20 easy?
brake horsepower and wheel horsepower are the same thing....usable horsepower. you mean whp or FHP <--- flywheel horsepower. how much the car makes at the crank.
Old 10-10-2004, 09:38 AM
im looking for horsepower to the rear wheels.
Will i be able to make it with the stock turbo, or do i have to upgrade.
Old 10-10-2004, 12:43 PM
you can make it with a stock turbo, but they are only good for so much psi. i would suggest an upgrade.
Old 10-10-2004, 09:15 PM
cool, im lookin for a somewhat easy/cheap way to break the 12 second barrier.
Old 10-10-2004, 10:43 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
Re: Re: Re: 300hp with rb20 easy?
Umm the factory ceramic turbo is only good for maybe 300hp total hp, not at the wheels. I wouldn't suggest boosting it much either as they fail quite easily.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 10-11-2004, 02:25 AM
Re: Re: Re: Re: 300hp with rb20 easy?
So then about the HP or less of a stock GT-R is all youll really get . Maybe an 2-6 swap is in order.
Old 10-11-2004, 07:37 AM
GTR2b's Avatar
GTR2b GTR2b is offline
There is no such thing as cheap and easy 12's.
Just FYI.
Old 10-11-2004, 09:35 AM
9ball 9ball is offline
My GTS-T has an upgraded exhaust/intake and boost controller, runs 16psi without problems, should make around 300hp but haven't been to a dyno, but there's no way in hell it can run a 12. I've turned it up to 1.4bar before but it pinged like hell so I backed off, but the turbo seems very capable at the 15-16 (1-1.1) range. With a ported head, large turbo, FMIC and so on I wouldn't see why 400hp wouldn't be easy. RB20DET.com is a great site for info on that engine.
Old 10-11-2004, 09:53 AM
Actually, that RB20DET.com site has a lot of sections that aren't up right now, sorry.
Old 10-11-2004, 12:00 PM
RazorGTR's Avatar
Skyline Man
Re: Re: Re: Re: Re: 300hp with rb20 easy?
And how do you come up with this? GTR turbos flow around 220 each. They have a very small exhaust housing with an A/R of .46 and since there are two of them, well you do the math.
Also keep in mind the standard injectors on an RB20 motor are 257cc each. The basic rule of thumb for measurement, since it is a 6 cyl is 1cc=1hp. You can make up slightly more with ignition timing but not a lot. There are so many variables in making hp.
Old 10-11-2004, 01:05 PM
is there any turbos from other nissans that bolt on? such as maybe from a 80's 300ZX? My friend has been boosting 15psi on his for 2 years, i beleive its a T3 turbo?
Oh by the way this is in a 240sx not a skyline, 300hp to the wheels should break into high 12's if i get decent traction.
A question about using bigger injectors: if i change the diameter of the MAF housing will the bigger injectors work, or do i still have to tune the ecu or use a safc.
Old 10-11-2004, 04:38 PM
Re: Re: Re: Re: Re: Re: 300hp with rb20 easy?
well you said it would hit up 300 at the crank, giving it a bit less than the hp of a stock GT-R at the wheels.
Old 10-11-2004, 10:42 PM
RazorGTR's Avatar
Skyline Man
When you are staying stock do you mean (engine) or completely factory standard?
