Go Back   Automotive Forums .com Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 09-16-2004, 12:10 PM   #1
seco
Banned
Voice Coils
I got 2 audiobahn 1600watts max 800 rms with dual voice coils and a 2ch 1000 watt amp can i connect 1ch on both voice coils?
seco is offline   Reply With Quote
Old 09-16-2004, 01:23 PM   #2
Haibane
Haibane's Avatar
Send a message via AIM to Haibane
Re: Voice Coils
you need a little more info. What amp? Are these dual 2 ohm voice coils, or dual 4 ohm? 1600 max means nothing btw. Only the rms matters. So which model amp. Who makes it.
www.cloudcity.deviantart.com
Haibane is offline   Reply With Quote
Old 09-16-2004, 01:44 PM   #3
EGcivicSi
EGcivicSi's Avatar
Re: Voice Coils
Like he said we need more info but from the looks of it your either going to be underpowering or overpowering.
95 Civic Si
00 Yamaha R6
EGcivicSi is offline   Reply With Quote
Old 09-16-2004, 01:46 PM   #4
Haibane
Haibane's Avatar
Re: Voice Coils
He will be underpowering it, but using the box that he will most like use. That is a better thing.
Old 09-16-2004, 01:48 PM   #5
Haibane
Haibane's Avatar
Re: Voice Coils
If you want to know a good box for audiobahns and more in depth detail of how to run audiobahns, you will want to talk to Stephen Matthews. Also you will get a better deal on an amp that will work better for it... If those were dual 4, I would have gone with a nine.1 or 2 of the amps you have currently and get a properly built ported box via Stephen Matthews, who can be reached at 678-662-1976
Old 09-16-2004, 05:14 PM   #6
seco
Banned
the subs are 400 rms dual 4ohm voice coils AW1251T and da amp is a legacy La770 1000watts 2ohm stablex2
Old 09-16-2004, 05:35 PM   #7
Haibane
Haibane's Avatar
Re: Voice Coils
ok. the subs would be wired series parallel bridged to the amp getting about 400 watts. My suggestion. Get a new amp. Get a nine.1 or something that is stable at 1 ohm and is a class D. That amp is pretty much worthless
Old 09-16-2004, 05:44 PM   #8
CBFryman
Banned
CBFryman's Avatar
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Voice Coils
^^the woofers are getting to be worthless also...some dude came up to me and said he would pay me $70 to build him a box for 2 legacy 8's...and an amp rack for a audiobahn amp...so he was backwards....he said he owuld only pay me if it hit over 126dB in his truck cab....i was like dude both companies suck....and in order to get anywhere near even 120dB i would have to port them which is nearly impossible in a regular cab truck....told him id sell him 2 old AW10's i have and he might hit over 120....told him 275 w/box (man i love rippen retards off)...he said he would think about it....
CBFryman is offline   Reply With Quote
Old 09-16-2004, 05:47 PM   #9
Haibane
Haibane's Avatar
Re: Voice Coils
actually the bahns aren't a sucking company. They just recommend bad boxes for their subs. You need to build the right box for them to work right. They don't take their rated power in a sealed box, only in a ported box.
Old 09-16-2004, 08:16 PM   #10
seco
Banned
so can i connect 1ch on both voice coils?
Old 09-16-2004, 09:19 PM   #11
Haibane
Haibane's Avatar
Re: Voice Coils
no, you bridge it to both subs, but dang, you won't even hear the subs. You will hear vocals out of it due to bad crossovers. you will be getting 200 watts to each sub. You will probably blow the subs underpowering them that much.
Old 09-16-2004, 10:07 PM   #12
EGcivicSi
EGcivicSi's Avatar
Re: Voice Coils
I had the same subs not to long ago, sold em already, but I had 460 watts going to each sub and they did hit pretty hard for the money. I had them in a ported box so that helped but I was in the high 120s running just one of them at 460. Didnt test with both of them. Good SPL sub for the money but SQ is in the toilet with them.
95 Civic Si
00 Yamaha R6
Old 09-16-2004, 10:19 PM   #13
Haibane
Haibane's Avatar
Re: Voice Coils
dude, I can get 140 with a single 15, you should have feeded it more power.
Old 09-16-2004, 11:37 PM   #14
EGcivicSi
EGcivicSi's Avatar
Re: Voice Coils
But the RMS on the thing is 400 and I was running it at 460 in a ported box. I dont think I could have hit much higher with just 1.
95 Civic Si
00 Yamaha R6
Old 09-16-2004, 11:42 PM   #15
bumpinstang77
bumpinstang77's Avatar
Send a message via AIM to bumpinstang77
Re: Voice Coils
put them in 2.5-3 cubes EACH and tune to 35hz.... give them a lot of port area and you will be suprised. I ran a pair for a very long time and I even overpowered them by 100 watts each and they took it for almost a year.... Theese are the best sounding audiobahns I've heard and they're not bad budget woofers.
bumpinstang77 is offline   Reply With Quote
