I just bought a new window circuit breaker for a 1992 newer styled 325i
and forgot which wire plugs in where, could someone please help? thanks |
Re: Please help! Window circuit breaker
doesnt matter all the switch does is open or close the circuit so it actually makes the two wires make contact to close the circuit, it don't matter
Thank you ever so much!
is it your windows locked up on you , if it isnt the breaker ,then it is your comfort relay located under the dash under steering wheel.
I tried the circuit breaker last night and nothing!
there isn't a fuse for it either, and if it wasn't for you I would have no idea ! I'll try that thanks! |
comfort relay cost only $17 at bavauto.com.
You are the Bimmerman !!!!!
=) it was the courtesy relay, it had a broken solder right in the middle, there is a web site some guy has that shows how to repair it and it worked !!!! thank you ever so much for your help .. I owe you a Mountain Dew ! thanks again,, crip |
hey crip...what problem did you have with your window? my passenger window has been acting funny for a couple of months now...everytime i try to close it it stops...the only way to close it is to keep pushing the button until it fully closes...this problem isn't really consistant either...it will do this half the time i use the window...maybe this could be a quick fix if this is what happened to your car...thanks for your time...
zgermans your problem is just the window switch not making good contact replace the window switch and it should work
Naw mine just quit working all together, sunroof and windows, Bimmerman has the answer,
later dude |
thanks guys...i found a switch at bavauto...when i get in ill let you know how it went...thanks again
Which relay is the comfort relay? I just want to go ahead and order it without pulling my kneed bolster out.
i think it was the top left one behind the dash under the steering wheel.
