Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 08-19-2004, 02:52 AM   #1
caniborrow50cnts
caniborrow50cnts's Avatar
Send a message via AIM to caniborrow50cnts
Question a/c recharging
I was told the best way to recharge the a/c of a 93' civic was to buy the retrofit kit, drain the system, and connect the adaptor to the low side. Is this a good way to tear up the system or the proper way to recharge with 134a?
caniborrow50cnts is offline   Reply With Quote
Old 08-19-2004, 09:51 PM   #2
sageuvagony
sageuvagony's Avatar
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
I did it, and cools at 31 degrees even in the hottest days. I have a 92. makse sure you change all 3 O rings.... I was told to get the green ones, not the black ones. you need about 8 oz of oil in there. There was no way I was going to pay 50 bucks a pound of R12. So now I pay 4 bucks for a can of R134
sageuvagony is offline   Reply With Quote
Old 08-19-2004, 11:29 PM   #3
caniborrow50cnts
Re: a/c recharging
Is that the proper way to do that though? I know on other cars though, the valve is on the compressor itself. Thats the only way I've ever been shown to recharge an a/c system.
Old 08-20-2004, 12:04 AM   #4
sageuvagony
the valves are right there when you open the hood. When you buy the retrofit kit, it just converts both valves and they are also color coded. One is red for high pressure side and blue for low pressure side. they sit right ontop of the ac radiator. They are 2 black caps.
Old 08-20-2004, 08:23 PM   #5
snowman2005
snowman2005's Avatar
Send a message via AIM to snowman2005
Re: a/c recharging
how hard is it to recharge. got any links to how to recharge ur ac.
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
snowman2005 is offline   Reply With Quote
Old 08-21-2004, 02:51 AM   #6
hundahunta
you need to drain the oil, out of the system. and replace o-rings and seals. zIf you do not replace the o-rings and oil, you will have leaks and possibly a compressor failure. the oil for r-12 is not compatible with the r-134 refrigerant and will seperate and cause a lack of lubrication!
hundahunta is offline   Reply With Quote
Old 08-23-2004, 09:24 PM   #7
jennihardi
Unhappy Re: a/c recharging
I need advice on how to improve the a/c in my '94 Honda Civic EX coupe, 1.6L? I've replaced all components, incl. compressor, a/c dryer, and condenser. The mechanic says there are no leaks, but the a/c still sucks. HELP. Any advice?
jennihardi is offline   Reply With Quote
