Go Back   Automotive Forums .com Car Chat > Chevrolet > Caprice
Old 09-08-2004, 02:16 PM   #1
pvoyager
Send a message via Yahoo to pvoyager
Angry 1986 Caprice
can someone help me. i have replaced the timing belt, brought it to number one compression, dropped in the distributer on number one, and got the firing order right, however my car still will not start. what else could the problem be or what did i not do right?
pvoyager is offline   Reply With Quote
Old 09-08-2004, 07:41 PM   #2
PeteA216
PeteA216's Avatar
Send a message via AIM to PeteA216
Re: 1986 Caprice
Is there fuel getting to the engine? Check the fuel lines, and especially the fuel filter. If you have the model with the carburetor, check your internal jets for dirt, you may possibly need to rebuild your carb (if you have a carb) If you have the throttle body injection system, check the connection to the jets, and the jets themselves. Your ECM (Electronic Control Module) or computer may be malfuntioning as well. To check for spark, remove plug #1, plug the wire into the spark plug while its removed, and set press the spark plug to a clean ground. Then watch for a steadily repeating spark while someone cranks the engine. If you have no spark or an erratic spark, check the power source to the distributor, your coil may also be shot.
PeteA216 is offline   Reply With Quote
