Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Old 06-30-2004, 08:10 PM
yearmax yearmax is offline
pwr window problems
Hello again ,
I am having some trouble with my passenger front pwr window . It will go up but wont go down . I have replaced the motoe and switch and still the samt issue.
I do feel the motor tryng to turn to go up but it does nothing when I hit it to go down .
What could this be ?
Old 08-20-2004, 04:28 PM
cabroncofan cabroncofan is offline
Re: pwr window problems
I just bought a 1995 Pathfinder and had the same problem with the right rear passenger window. I wound up taking the switch apart and using some fine sand paper on the contacts. I put everything back together carefully and it works fine now. The whole process took maybe 10-15 minutes, you just have to be careful when pulling the switch apart things don't go flying. The dealer wanted $135.00 for a new switch. You can also use a little di-electric grease on the contacts and pins when you put it back together, maybe $7.00 from your local auto parts store. Good luck !
