Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Old 08-16-2004, 11:51 AM
boostdog boostdog is offline
Send a message via MSN to boostdog
Angry 1gen fuel pump..broke the fuel line! what should i replace it with?
ok went to install the walbro pump that i have and i broke the fuel line right before it makes the 90 bend out of the pump cap. i have been looking at earls fittings and fuel lines and was wondering what you guys have used to replace the line?
Old 08-16-2004, 12:01 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: 1gen fuel pump..broke the fuel line! what should i replace it with?
you need to take a picture cause it sounds to me like your pump cap is fucked... did you break it right at the cap or the line comes off the cap, makes the 90 degree bend then you broke it? so more or less is the 90 degree bend still attached to the pump line?
Old 08-16-2004, 12:17 PM
ya it broke just a little above the cap. it is actually just a pin home leak. is it still screwed up? could i use fuel hose and a clamp to keep it from leaking?
Old 08-16-2004, 12:33 PM
EclipseRST's Avatar
Banned
did you bend it? i wouldnt just "clamp it" that seems like a half ass way of doin it!
Old 08-16-2004, 12:53 PM
bend it? if i bent it it was just a little. i was trying to be as careful as possible but tuged a little on it and it sprang a leak. but just a pin hole size. i was thinking that if i could get the whole thing out i could slip some hose over the pin hole and clamp it down...what about jb weld? does it hold up to gas and the pressure that the pump will make? keep in mind it is just a pin hole.
Old 08-16-2004, 12:58 PM
EclipseRST's Avatar
Banned
yea but the thing is the pin hole could get bigger or it could eventually break... i have one if you want to buy it! make me an offer or do whatever you like...
