Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 04-20-2004, 12:48 AM
CalicoDreams CalicoDreams is offline
Ram Air Hood
I was thinking about a dual Ram Air hood for a Fiero, It would look real nice. does anybody know of a website for a Fiero Ram Air hood, or a hood that fit, or maybe a kit that is just the scoops that you bolt on to the exsisting hood. all info is welcome and greatly appreciated.
Old 04-20-2004, 06:17 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: Ram Air Hood
Obviously you couldn't put a working ram air hood on a Fiero since there's no simple way of getting the air from the spare tire compartment up front to the engine compartment in back. If you're looking for a real cold air system they do make roof induction kits(don't know where though). If you want the ram air scoops for pure looks only, J C Whitney has a nice selection, you can see it at http://www.jcwhitney.com/webapp/wcs/...10222&ss=10101
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 04-20-2004, 11:37 PM
Indy-1's Avatar
Indy-1 Indy-1 is offline
Send a message via AIM to Indy-1
Re: Ram Air Hood
Having a ram air effect on the front of the hood would work in helping to keep the radiator cool if done correctly. I have seen quite a few designs that do a great job in doing this. As for the engine in back, many have added rear deck scoops, over the roof scoops, deck vent scoops, etc.
Old 04-21-2004, 12:55 AM
Exclamation ummmm my bad
I'm not really looking for a functional ram hood. I'm just looking for the look of a ram air hood. Maybe just some mounted pieces that I could mount on. I think that they have the best style and look for what im going at.
Old 04-24-2004, 09:07 AM
Indy-1's Avatar
http://www.fieroshop.com.au/estore/index.php?cat_id=10&catname='Hood%20Scoops'
They show these on a truck but obviously being generic scoops will go on anything:
http://www.ultimateautoaccessories.c...ood_Scoops.htm
Old 09-02-2004, 04:30 PM
goatnipples2002 goatnipples2002 is offline
Re: Ram Air Hood
would a hood scoop on the rear deck help keep the engine cool? Is there enough low pressure (vacuum) for the rear deck scoop to help any?
Turbo 351w E85
Old 09-02-2004, 10:15 PM
Re: Ram Air Hood
I doubt decklid scoops would pick up enough air to do much good - at least on the notchbacks, with a fastback you might have better luck. I was daydreaming at work the other day (ok, so I do it everyday) and thought of mounting high powered 12 volt fans under the vent louvers - blowing outward - to pull out hot air from the engine compartment and in the process pick up cooler air from underneath the car. Crazy, but worth a shot...
Wanted to buy:
Old 09-03-2004, 04:15 PM
Re: Ram Air Hood
I will give it a try because it is only a rear decklid the will be destroyed if it doesn't work.
Turbo 351w E85
