Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 08-12-2004, 01:01 PM
speedsters9 speedsters9 is offline
Send a message via MSN to speedsters9
lower ball joint check
I replaced my front two upper control arms and was wondering how do you check the lower ball joint to see if it's wore out. Anyone done this and have suggestions on how to check it?
91 EX-R
AEM CAI, Strut tower Bar, Monroe Sensatrac struts, Moog sway bar and stabalizer bushings.
Old 08-12-2004, 03:06 PM
gitter44 gitter44 is offline
Take a large flat blade screwdriver or prybar and pry up and down between the balljoint and the lower control arm to check for movement... there should be no play (movement) between the balljoint and control arm. If there is you should replace them. Also make sure there are no tears or rips in the balljoint boots.
