Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 09-27-2004, 12:37 AM
denalae denalae is offline
whining when engine starts
My 92 accord EX whines when I start the engine. It sometimes stops when I put it in gear, but usually goes on for a couple minutes. If I turn the A/C on, it changes frequencies and kinda slows down. Anyone know what this is, if I can do it with almost no car maint. experience, or how much it should cost? Thanks a bunch!
Old 09-27-2004, 01:00 AM
whatsupzaflo whatsupzaflo is offline
Send a message via AIM to whatsupzaflo
Re: whining when engine starts
sounds like your timing is off but if it sounds more like squeaking then its loose belts
Old 09-27-2004, 12:24 PM
AccordCodger AccordCodger is offline
Could be a bunch of things - alternator, compressor etc. You need to get a better idea of exactly where the noise is coming from.
Old 09-27-2004, 05:27 PM
phantastic1 phantastic1 is offline
first thing you can try is take a can of dw-40 and spray the pulleys. if the noise goes away then it's probably 1 of 2 things. the tension of the belt is incorrect or the belts are starting to crack. next thing to check for is if any of the pulley's are damaged or worn. most common pulley to give out first would be the idler. you would need to remove all the belts in order to check the pulleys. once all the belts are removed...spin each pulley to see if there is anything restricting it to spin.
Old 09-28-2004, 12:37 PM
I dont know where they pulleys are...Are they hard to get to?
Old 09-28-2004, 01:10 PM
I'm a little concerned that if you don't know where the pulleys are, then you should seek the advice of a mechanic.
Avoid the Honda dealership and most places like Midas. Often a small gas station that also does repairs can give you good advice - their (sometimes only) mechanic is often very experienced.
I'm also not in agreement with spraying the pulleys with WD-40. It's a petroleum product, and if your belts weren't wearing out before, they will pretty soon after.
