Anybody ever built a B20 stroker? I'm looking to get a new car soon, and up until recently I was going to get something like a 5.0 liter Mustang or a LT1/LS1 F-body. Due to insurance reasons, however, there's no way I'd be able to keep either of these on the road (just got 2 tickets for Unsafe Start/Improper U-turn doing donuts in a friends 328i). So now I'm looking to get a Civic hatchback, probably an Hx or Cx (doesn't get much cheaper to insure than that) and dropping in a fully built naturally aspirated B series. Just wanted to know if anyone had ever stroked a B20 and what rod length did you use as well as where did you get the crank/rods for it? I'm also considering throwing a VTEC head on it while I'm building it.
stroked b20
A B20 block is pretty much a stroked version of the B18. I think its just a larger bore or something like that which nets the extra .2 liter.
If you want a quick motor...build a turbo B20 with like a b16 or GSR head. Just dont rev it too high. |
Stroking a motor involves using a shorter rod length and increasing the length of the crankshaft throws so that the piston travels farther, increasing the displacement. I realize that to have a larger displacement on a B-series (2.0 vs. 1.8), the cylinder bore would have to be larger, but I'm looking to see if anyone has stroked a B20. I was thinking about going with a turbocharged setup for a while, but I've decided to stay naturally aspirated for now for simplicity.
b20
ive never heard of anyone stroking a 2.0 and im not sure how the all motor b20 performs. Lots of torque...
Yeah, basically what I'm looking to build is a B-series to drop in a Civic hatchback that'll put well over 200 ft-lbs to wheels throughout much of the powerband, naturally aspirated on 93 octane gas. It might take a lot more time and effort than going with a supercharger or a turbocharger, but thats not what I'm looking to do.
b20
yea naturally aspirated is more challenging in my opinion than just bolting on a turbo and goin...i think its a lot more fun too.
Yeah, I've seen some kits that have it end up with like a 2.2 liter displacement, which is pretty sick and most likely makes a lot of torque.
Thats a good question actually. I dont know if they have kits for it but i think you can get 84.5 mm sleeves which makes it a 2.2.
crower makes 2.2 liter stroker kit. the last time i checked i think its a little over $2000. i've seen stroked b16 to 1.8 liter and it ran great, but i don't know about a 2.2 liter tho.
The stroker kit for the b18b1 will work in the b20,all you need is larger pistons b/c the bore in the b20 is bigger than the b18b1. The two motors are the same, the b20 is a b18b1 with a bigger bore. The two motors use the same crank and rods.
Thanks for the info. You don't happen to know what results people have seen from the Crower B18 stroker kit? Just looking for a general idea of how much power it'd be making.
b20 stroked
A B20 Vtec build is known for the torque you get...id almost be scared to see what a turbo b20 stroked would do.
Is it the torque youre after because it would probably be cheaper going the H22 route |
sorry i dont know the results for a 2.2 stroker, but i saw a 2 liter gsr that make 240hp and 173tq at the wheels naturally aspirated, but it was fully built. so imma guessing you should make more for a 2.2 liter. like mastarolla said it would probably be cheaper if you got a h22.
Yeah, the main reason I wasn't looking to put a H22 in was because of the increased weight. I wanted to have a car that would still be decent through the turns. Kind of an all-around autocross/drag-strip car.
