Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 08-22-2006, 03:38 PM   #1
Mango™
Mango™'s Avatar
91 s-10 putters on highway
When I am going down the highway, my truck looses gas flow, this is of and on. Only on the highway whenI am at a constant speed. It idols smooth. I recently put in a new long block, new plugs, wire, oil, trans fluid, antifreeze, egr valve.
I had all the vacuums replaced and professionally done.
Any ideads?
91 s-10, v6, 4.3l
Thanks
Mango™ is offline   Reply With Quote
Old 08-22-2006, 11:40 PM   #2
jackass#1
jackass#1's Avatar
Send a message via Yahoo to jackass#1
Re: 91 s-10 putters on highway
fuel pressure check. when you done the engine swap did you change out the computer?
jackass#1 is offline   Reply With Quote
Old 08-25-2006, 02:13 PM   #3
Mango™
Mango™'s Avatar
no I did not change out the computer. What would that do and what do they usually cost? I noticed when going up hills it really putters, idle is ok.
Old 08-25-2006, 10:21 PM   #4
joshmitch05
Shouldn't need a new computer unless you went to a different motor from what was in there. (IE, going from a 2.5 to a 4.3)
joshmitch05 is offline   Reply With Quote
Old 08-27-2006, 02:00 PM   #5
tom3
Sure sounds like low fuel pressure. Change filter then put in a new fuel pump if still acting up.
tom3 is offline   Reply With Quote
