Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 07-20-2004, 12:47 AM   #1
nuck
Will removing car battery blank the key fob program?
Changed the battery in my 97 Malibu and the radio went Delco on me and the key fob doesn't work. I reset the radio but I am wondering if maybe it was just a coincidence that the fob battery croaked at the same time, or is it an expected result that the the fob becomes unprogrammed?
nuck is offline   Reply With Quote
Old 07-20-2004, 06:42 AM   #2
wpbharry
I had the battery replaced twice on my '98 LS, and neither the radio or the key FOB needed resetting. I assume the radio must have memory retention for a short time, like certain VCRs, etc.
Key FOB probably needs a battery, although, despite the fact that the Owner's Manual says they should only last 2 years, the 2 on my '98 made it 4 and 5, respectively.
wpbharry is offline   Reply With Quote
Old 07-26-2004, 08:17 PM   #3
nuck
Dead battery DID erase programming on mi key fob
Bought a new battery for the fob and it still didn't work. Searched this site for how to reprogram the fob and successfully reset it. Maybe it depends on how long the battery was dead for(a week or so)but no other explanation.
Old 07-27-2004, 08:42 AM   #4
e2helper
Re: Will removing car battery blank the key fob program?
Just to confirm what you thought:
Resynchronization may be necessary due to the security method used by the remote control door lock receiver system. The transmitter does not send the same signal twice to the receiver. The receiver will not respond to a signal that has been sent previously. This prevents recording and playing back the signal from the transmitter.
Resynchronization does not send the mathematical formula to the receiver. Resynchronization verifies the previously programmed mathematical formula in the transmitter. Resynchronization works only if the transmitter is already programmed.
Resynchronization may be necessary under the following conditions:
The transmitter is weak.
The transmitter battery was changed.
The vehicle battery is very weak.
The vehicle battery was changed.
The vehicle battery was disconnected.
The transmitter is pressed more than 255 times outside the range of the receiver.
In order to resynchronize the transmitter with the receiver, complete the following steps:
Depress the lock and unlock buttons on the transmitter simultaneously for 7 seconds.
The receiver will acknowledge resynchronization in the following manner:
If all of the doors are locked, the receiver will unlock and lock all of the doors except the drivers door.
If all of the doors are unlocked, the receiver will lock all of the doors.
e2helper is offline   Reply With Quote
