Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-02-2005, 10:24 PM
Saskatoonian Saskatoonian is offline
95' Contour Speed Sensor Code HELP!
1995 V6 Duratec
this code comes on only on highway speeds
engine light came on, scan shows code 452
" Insufficient Input From Vehicle Speed Sensor To PCM"
anyone had this code before? Where is this sensor?
Does replacing it help? Can it be cleaned/fixed?
Thanks!
Old 03-02-2005, 11:49 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Your VSS should be locate at the tail of the tranny, very close to the left axle shaft, with one retaining bolt. Cant clean a sensor, since its full of electronics.
btw, some possible symptons of a bad vss.
-the speedometer falls to zero;
-simultaneously the O/D light starts flashing;
-the check engine light comes on;
-no overdrive...engine revs climb to ~ 4000 rpm
-ATx seems a bit confused...need to manually select some gears and a bit sluggish in upshifting.
-no other prior symptoms, car was shifting fine and all gears were available.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
