Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Old 07-24-2004, 11:15 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
K&N Question
whats the diffrence other then $ between these?
95-99 eclipe turbo filter & pipe
http://cgi.ebay.com/ebaymotors/ws/eB...category=33659
95-99 Fipk
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
DSM geek
Old 07-25-2004, 12:12 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: K&N Question
the top one is just a regular run of the mill air intake
but the bottom one is better because it is the fipk and probally will give u more preformance
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 07-25-2004, 12:40 AM
joemathews's Avatar
joemathews joemathews is offline
Re: K&N Question
Not a whole lot...the FIPK is generally considered better, but the amount of hp it will give you over a regular k&n is minimal for the price, IMO.
"Fuel Injection Performance KIts (FIPK’s) contain a high air flow K&N filter with uniquely designed adapters. This creates a radius entry allowing the engine to ingest a greater volume of air compared to the factory intake system. "
So, chances are that the FIPK is a little higher flowing filter and adapter. If you have the money, go for the FIPK...if you are trying to do things inexpensively, just get the regular k&n or similar filter. Either is 10x better than stock
1996 Eagle Talon
Old 07-25-2004, 02:03 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: K&N Question
if youre on a budget, the cheaper one would probably work almost just as good as the FIPK. Honestly, they both increase the intake radius like crazy, I still dont see too much of a difference except for the fancy FIPK name.
The daily driver. The weekend cruiser. The lazy shop hog.
