Old 07-17-2004, 05:01 PM
91siturbo 91siturbo is offline
How much boost???
I have a 91 civic si with stock internals, and im in the process of turbo-ing it what is the max psi of boost i can run without blowing my motor???
Thanks
Old 07-17-2004, 05:18 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
Re: How much boost???
it depends on your tuning. Im assuming since you're asking such a question, you dont know much about turbo hondas, so i will say 5-10psi.
It all depends on your fuel and spark management. with an FMU setup, 5-7psi. AFC hack is good for about 7-10psi. with a very good dyno tune on a modified ECU, i've seen people run up to 15psi on a stock block d16.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 07-17-2004, 05:45 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I think 10 is pushin it on stock internals. You might be able to boost that but dont expect the motor to last you long. It'll wear out quick. 5-7 psi is what usually ppl boost to .
Old 07-18-2004, 12:56 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
5psi on all stock, if you put head studs and crank studs on 8psi max more motor mods like different pistons, bearings, and rings you can safely go up to 13-15psi and peaks of 16+ but not for too long. And of course make sure the hooker is rich and retarted. That sounds funny LOL
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 07-18-2004, 03:59 AM
Rufes1's Avatar
Rufes1 Rufes1 is offline
Send a message via ICQ to Rufes1
On a d16a (SOHC Vtec) and for the other d16's you can easily run 10 - 11psi everyday with fmic, upgraded injectors and a good tune.
Weakest part in them are the rods, which are good for ~220hp
Msn; Click
Old 07-18-2004, 11:35 PM
Cjz89civic's Avatar
AF Premium User
you try running 10-11psi on your Si block daily and will see you asking around for a si block in about 2 months. NOT ON YOUR LIFE would I run 10-11psi on a stock block especially if it was my everyday car.
I know a little about boosting stock motor I have done LOTS of reseach on bossting, Not to say it has not been done, but the thing is you will run into problems. Another thing is these motors have over 100,000 miles and the ablity to hold boost is greatly comprimized but the rings being worn well you get my point dont do it.
