Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Old 08-01-2004, 12:33 PM
ninja_zx7r ninja_zx7r is offline
rs stalls after warm up
im working on a 95 rs the car starts find but i guess once it warms up it has a rough idle and stalls out also set codes which i check by cycling the key and it come up as 12 13 55 any help ty
Old 08-01-2004, 12:35 PM
rs 2 problem
also when its doing that the stalling or rough idle if you steo on the gas it will cut out at 3500 rpm like what a limiter does any help ty
this has been merge into this thread because you do not need to start 2 threads about the same topic...
~EclipseRST
Old 08-01-2004, 12:43 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Code 11..... Intermittent loss of crankshaft and/or camshaft position sensor signals to PCM, complete loss of crankshaft position sensor signal to PCM, or timing belt skipped one or more teeth
Code 13..... Problem with the MAP sensor circuit
Code 14..... MAP sensor voltage out of normal range
Code 54..... No camshaft position sensor signal. Problem with the sensor or circuit.
Those are the only ones I could find that matched or were close to the code numbers you have. Maybe someone here can explain these codes cause I can't Hope the helps
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
