Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Talk
Old 07-20-2004, 11:07 PM
spider1604 spider1604 is offline
'91 LX Brake Light Switch
Were is the switch that turns the brake lights on when you mash the pedal on a '91 Mustang? Is there a trick to removing it?
Thanks.
Old 07-21-2004, 12:14 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
The brake light switch? It should be right on the brake pedal. I've never done one on a mustang, but it should be like a cotter pin type clip. Then disconnect the connecter and pull it off.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
