Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 06-24-2004, 09:23 AM
driver 000 driver 000 is offline
93 civic - won't start in hot weather
i need help with my 93 civic ex coupe, 230k miles, manual trans., i'm the original owner.
live in new england. starting last week, warm temp. afternoons (80+) after work (5pm+), car won't start. plenty of charge, can't seem to get gas. leave it, try again in morning when cooler, starts right up.
had been a long while between tuneups so had that done. was cool for the next 5 days until last night, when it was again over 80 degrees - same thing - can't seem to get any fuel. again, started right up this morning.
need to get it to my mechanic, but want to tell him all this without thinking I'm a dope. so, has anyone ever heard of this happening, and if so, what it turned out to be? obviously, the car has been great for me for over 11 years and it's probably nearing the end, don't want to put too much $ into it but want it fixed.
i need help, quick! thanks to all.
Old 06-25-2004, 07:03 PM
94civic's Avatar
94civic 94civic is offline
Re: 93 civic - won't start in hot weather
could be vapor lock or the main relay. i would check the relay first.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 06-29-2004, 03:37 PM
JDMrexBoi's Avatar
JDMrexBoi JDMrexBoi is offline
Banned
its a vapor lock! my did that only when it gets hot let the car cool down or check the vacuum hoses see if there touching something hot and maybe thats your problem.
Old 07-07-2004, 06:32 PM
slickrick32097 slickrick32097 is offline
mine does it all the time. looked on the internet and it says it was the oxygen sensor that runs into the engine. can't really explain where it is at but it is a little plug that runs into the back of the engine. until you can replace it, all you have to do it wiggle it a little bit and it will start right up.
Old 07-09-2004, 07:22 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
Yall are not the only people with this problem....
http://www.automotiveforums.com/vbul....php?p=2022050
Ya, It's Turboed.
