Old 01-23-2004, 09:30 PM   #1
das6505
wheel hub assembly
wow Twilight Zone (Auto Zone) Not bad foud one in my area whole assembly bout $140 just like someone said. now all I have to do is put it on. hope its not that hard.
das6505 is offline   Reply With Quote
Old 07-06-2004, 08:51 PM   #2
chevy21
is your vehicle 4wdrive
what year is it
chevy21 is offline   Reply With Quote
Old 07-07-2004, 01:01 AM   #3
das6505
wheel hub assembly
Its a 1999. It wasn't too hard to change. you need socket big enough to fit the hub nut and a breaker bar to break it loose. then there are 3 bolts on the back of the hub you have to take out. Then knock the axle out of the center of the hub, disconect thr ABS wire and that should be it.
Old 07-07-2004, 10:41 AM   #4
quaddriver
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Caveat - do not let the vehicle weight rest on the wheel without the axle nut being tightened down or else the hub will be destroyed.
quaddriver is offline   Reply With Quote
Another 2004 Alero hub assembly and front brake question. Seattle Al Alero 3 02-20-2009 08:38 AM
92 325i rear wheel hub assembly install Leafman 3 Series 0 05-18-2005 10:15 AM
F/S Wheel Hub Assembly for Sonata skeeter74 Classifieds 0 04-04-2005 11:58 AM
Front Wheel Hub Assembly 2000 Blazer 2WD kjaker Blazer 5 02-20-2005 08:37 PM
Help! Front wheel hub assembly removal dubltap Blazer 1 10-09-2004 08:41 PM
