Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > C/K
Old 05-19-2004, 10:38 AM   #1
WharfRat
Need Air Conditioning Help (97 1500 Sub)
Tried the A/C for the first time this year and I am getting cold air from the rear vents only. I guess it is some kind of diverter problem, but I have no idea where to start looking. What is in the big black box under the pass. side dash? Can anyone shed some light as to where/what the problem might be? I'd hate to pay the dealer big bucks to fix something that might just take me a few minutes to fix.
Thanks
Rich
WharfRat is offline   Reply With Quote
Old 05-24-2004, 12:49 PM   #2
scoteric
Re: Need Air Conditioning Help (97 1500 Sub)
I had the same problem on my 1999. I put dye in the system and started looking for leaks. The compessor was leaking from the seam. I replaced the compressor, drier and orifice tube. I started to charge the system and had the front vents were cooling to 40 F. I then found a second leak in the outlet hose returning from the rear air. I suppose with the new pump the pressure was more than with the old. I also checked the evaporator under the dash and there was no dye on it so it was not leaking. I hope this helps a little.
scoteric is offline   Reply With Quote
Old 06-08-2004, 12:35 AM   #3
speed1628
Send a message via AIM to speed1628
Thanks
Rich
thereare vacum actuators in the A/C box that open and close doors to redirect the airflowit is either stuck or the vacum hose has a leak or is disconnected
speed1628 is offline   Reply With Quote
Old 07-07-2004, 02:12 PM   #4
bpalmer
RE: Air Conditioning (97 1500 Sub)
Ever get the problem solved? I've got the same problem, cold air from rear vents, luke warm air from front vents. Putting a can of freon in it earlier this year only made the rear air colder..
Thanks for any help
bpalmer is offline   Reply With Quote
