My S10 Blazer is bucking and smells like rotten eggs all of the sudden. I bought it about 1 month ago with 91K ran a little rough. I changed the plugs, Spark plug wires cap and rotor after all was replaced truck ran very good. NOW all of the sudden it has started bucking and running like crap. I wanted to know if anyone elde had this kind of problem and if they did what was done to fix it. I do remember having an old Oldsmobile and it did this when the EGR valve went on it. Could this be?
Year/motor/injection system?
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: 94 Blazer 4.3 bucking when idle
i had this problem turned out to be leaking fuel lines inside intake, i have cpi check the plugs if they are fouled on one side only that may be your problem. all three plugs on the driver side were fouled which indicated the fuel lines if they are on the passenger side it may be your fuel regulator
#4 | ||
#5 | ||
Re: Re: 94 Blazer 4.3 bucking when idle
#6 | ||
Re: Re: Re: 94 Blazer 4.3 bucking when idle
#7 | ||
Re: Re: Re: Re: 94 Blazer 4.3 bucking when idle
#8 | |
Just a little info. when i changed mine out everything went super easy except for getting the bolt out that holds the retaining plate for the fuel lines it is a t30 torx. but you have very limited space to get it out and it is also hard to see . it is very easy to strip be careful! i stripped mine and had to go to sears to buy a low profile bolt out kit about 30 bucks, but i finally got it out. Also i installed a kleen screen gasket on my egr port it is a gasket with a fine mesh screen to prevent large chunks of carbon getting stuck in the egr.
#9 | |
![]() Join Date: Jun 2004
If that doesn't solve your problem check the cat, unplug the o2 sensor before the cat, if it runs better you might have a blocked cat, that sometimes makes the car smell like rotten eggs a lot of times, i had that problem with my blazer, not to hard of a fix.
#10 | |
So what's the verdict?
#11 | |
I've got a '95 that just started doing the same thing this week.. haven't had a chance to get to autozone to get the codes out of the computer yet.. but I'm interested in hearing what the verdict is as well... may give some insight as to whats up with my truck.
only other additional thing is that mine engines been fluctuating between running normal temp and -hot- (enough to light up the check gauges light).. i replaced the thermostat about a month and a half ago.. and symptom dissappeared.. but it has slowly started creeping up into the orange zone again -vballfun |
#12 | |
When was the last time you flushed your cooling system? Sounds like you have a blockage
#13 | |
Had the radiator repaired last summer at a local radiator/A.C. shop. I do not know if they would have flushed the system as a test for leaks or not. Ran fine all winter and just this April did it start heating up.. However that was my thought (about flushing) as well, and was my next move.. just haven't been able to get to it yet. (looking at what little rises up into the overflow tank the coolant is looking pretty murky/opaque... shouldn't it be some degree of translucent?)
#14 | |
It should be translucent green...
#15 | ||
