Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-21-2006, 08:33 PM
[email protected] cathyoc@gmail.com is offline
Cool 98Jeep Grand Cherokee leak on floor
I have a V6 Grand Cherokee, automatic trans, 1998. Recently, I have noticed water on the passenger side floor. There is no odor to the water. It is more noticable in the AM's, after the car sits outside overnight. It seems to be coming from the area near the fuse Panel on the passenger side front.
It's driving me crazy. If it is a plugged AC line, where do I find that and what does it look like. I can't find any other place it may be coming into my car. HELP!!!! And thank you!!!!
Old 07-22-2006, 09:16 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 98Jeep Grand Cherokee leak on floor
Hi Cathy, and Welcome to AF.
It sounds like the AC draintube is clogged on that side. Its purpose is to drain the condensation from the AC running out the bottom of the vehicle. When it backs up you get water in the passenger side, just as you described.
I don't know the exact location on your Jeep, but take a look up under the vehicle, passenger side, near the firewall. You should see a small tube coming out from underneath. If you run a slim wire up into it, you should be able to clear the clog, if that's the problem.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-22-2006, 05:57 PM
Thank you so much, I will check it out, and let you know if it works. Thanx for your help.
Old 07-23-2006, 11:00 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
How come the "Grand" Cherokee people got on here? It is not the same SUV.
My "cherokee" leak was from the windshield, My AC drain goes outside and leaves a puddle there if it is draining right.
Anyway, the water comes from sitting outside overnight, because when parked on the street it slopes to the right. The moisture then drains down the windshield to the leaking seal at the lower right (passenger side) of the windscreen.
Took me a long time to figure that one out, had to used compressed air to verifiy the wicking that was doing it.
Old 07-24-2006, 06:10 PM
I found the hose in the wheel well on the passenger side. It belongs to the overflow for the coolant (radiator). I do own a '98 Grand Cherokee, so if I can get any help on fnding the a/c drain hose--it would be greatly appreciated.
Old 07-24-2006, 06:53 PM
AlohaBra's Avatar
I still think you have a windshield leak. You said you find water there in the AM before AC has been used. My windshield leak came down by the right hand fuse box also. Especially in the winter. Run a hose on the windshield, remove the cover for the fuse box, remove the glove box and have a look while the hose is going. You might have to get someone to help you.
The AC drain hose goes through the floor fowand into the engine compartment and into the frame. Then when you use the AC water will drip from this drain hose to the center of the vehicle.
Old 07-25-2006, 02:56 PM
legalfee legalfee is offline
There's no way to get to the drain tube from under the Jeep. To clear the drain pull down the carpet on the passenger floorboard and drill a 1/4 inch hole in the middle of the evaporator drain housing. Here is the link to the TSB: http://home.sc.rr.com/janet/TSB/24-06-96.htm
1984 AMC Wagoneer Limited (RIP - Burned)
1996 Chrysler Grand Cherokee Limited (for sale)
1999 Chrysler Sebring Convertible JXi
2004 BMW X3
