| Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
![]() Join Date: Jul 2002
Short Ram vs CAI.
someone just told me that a short intake tube is better than a CAI. how could this be? the air inside the engine bay is really hot. (especially my car) which is why im running CAI as opposed to short ram.
I know for some cars this varies and you have to experiment, but in general...
96 EJ6. Future home of boosted B18C1.
Re: Short Ram vs CAI.
they make no difference. And when your driving the air inside the engine bay isnt hot, its the same as the outside air.
Why don't you try using a hairdryer blowing towards your face on "high heat", then set it to "cool". You will feel a difference
Depending on whether your car uses a Carb or FI. A short intake that would be pulling air from the inside of the engine bay, which will be hotter will help keep fuel atomized which helps in creating more power even though the desity of the air may be lower. For FI its already fairly close to the intake valve so it isn't given much time to cool and condense so using a short intake or a CAI might not make much of a difference.
Not that either of these will, unless its winter or something.
I disregard my perceived image in the persuit of knowledge. |
ok its not the difference of a hair dryer or not. So you mean to tell me that air going into your engine at 45 MPH is going to be just as hot as if your engine was sitting still? i dont think so. When your moving air is constantly being circulated around in their, faster and more volume than what is able to be heated up. Not to mention that with cold air the air travels a longer distance and through more bends in a pipe which will cause drag and turbulanc ein the air slowing it down.
Won't the engine get hotter as the revs go up?
#7 | ||
Re: Re: Short Ram vs CAI.
Wait a minute, you mean to say a bottle of pop is bigger than your engine?? "Pain is weakness leaving your body" There is NO replacement, for displacement... 2007 Kawasaki ZX10-R S.E.
#8 | |
For every 11 degree drop in intake air temp, you gain 1 hp....you figure it out
#9 | |
![]() Join Date: Nov 2001
The air under the hood is quite hot, especially during a hot summer day. It doesn't matter if the car is moving the temperature will be higher under the hood anyway, remember that the air is first heated by the radiator and in some cases oil coolers, A/C condensor, and intercoolers before it gets into the engine where it's heated further, probably with the same amount it was heated by the radiator. 60-70 degC isn't uncommon under the hood, which means that you will loose some power.
Basicly, if we can take air that is colder and denser the better it will be. Rarely any new cars take hot air from under the hood. The length of the itake pipe has also a tuning effect on the intake. The gain from colder air will depend on the engine power, it's a percentage number so to speak. |
#10 | |
The air unde the hood is indeed quite hot. The air isn't flowing through there at the rate as you are moving for one. Second, its getting heated as it enters the bay and crosses over the radiator. Third, the engine itself is over 100 degrees, the exhaust is several hundred and there are dead spots for air movement within the engine bay. Underhood temps are often 150-175 degrees F and when in heavy traffic, spots can see well over 200. So even "hot" 90 degree ambient air is an improvement. And as cshky04, for about every 11 degree F drop in temp, you can about 1 hp.
Car: 2003 Malibu (Base) Modifications: KC Fog lamps, autodimming rearview mirror w/ compass&temperature, window tinting, rear speakers, front speakers, sub, synthetic ATF & aux tranny cooler. Future modications: Dynamat interior, alloy wheels & new tires, intake, exhaust & intake manifold??? |
#11 | |
get either. the HP gains you see will result in you free-ing up your intake, not in whether its hot or cold. think about it, your intake manifold is going to heat whatever "cold" air you bring in, so the difference between the two will be neglegable. especially
you wont find any difference in the way it drives if you switch to a shorter intake. so dont bother
i love him whose soul is deep, even in being wounded. |
#12 | |
So you guys are saying that if I bought a $300 cold air intake, I just wasted money?! And I don't even get as much HP compared to a short ram which only costs slightly above $100?
#13 | |
Chances are that you will not notice the power increase made by either, let alone tell the difference between the two.
There is however a difference between hot air and cold air, and while the intake manifold may become heat soaked and heat the intake air to some extent, that effect is far superior to simply sucking in the hot ambient air in the engine bay. The heat transferred by the intake manifold will be fairly negligible when compared to the heat of the ambient air in the engine bay. I have always thought that $300 for what is essentially a shaped tube is excessive, however they do increase your power...just not by enough of a margin that you can expect to feel the increase. Although, the effect of modifications is cumulative, and having a better positioned and less restrictive intake will help to make the most out of any future modifications.
Beer tastes better upside down. Last edited by Sluttypatton on 13-54-2098 at 25:75 PM. |
#14 | |
So you are saying that the heat in the intake manifold wouldn't make the air coming through, hot?
"intake manifold may become heat soaked and heat the intake air to some extent, that effect is far superior to simply sucking in the hot ambient air in the engine bay." What does this mean? |
#15 | |
Basically what I'm saying is that although the manifold may get hot and heat the intake air a bit, it is still better to locate your air filter at the coldest possible location than just leaving it in a hot area of the engine bay. Sometime I'll get around to measuring the manifold temperatures with my CAI and factory airbox, so I can provide some firsthand numbers. It might take a little while however, I'm pretty busy during the days right now.
