Old 05-26-2004, 09:12 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
tranny question
got a quick question, going to look at a tranny friday, he told me its off a dohc ZC so i wanna see if its an actual ZC tranny, or an Si tranny or a DX tranny, how can i tell these apart?? and if its a true ZC tranny look in the classifieds saturday prolly cuz i wont be using it as i dont have the axels for it.
thanx to the people who respond before friday night!
later
Old 05-26-2004, 09:42 PM
n2o_2k's Avatar
n2o_2k n2o_2k is offline
Re: tranny question
Look for PL3/3000 cast into the casing just above the fill plug for a si tranny.
PL3/A000 or A100 denotes the smaller bearing HF, DX, STD tranny.
Read more here http://www.honda-tech.com/zerothread?id=98181
Old 05-27-2004, 07:25 AM
1PhatCX's Avatar
are there any advantages to using the Si tranny? and if it is a real ZC tranny would there be any advantage to go buy new axels and use that tranny??
Old 05-27-2004, 08:17 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Si trany has shorter gears than the DX tranny. The DX was built more for gas economy while the Si was built more towards acceleration. So the Si will make your car speed up quicker than the DX tranny. Then theres the ZC. This has even shorter gears than the Si tranny so that rpm drop between shifts is less. So you'll speed up even quicker with the ZC tranny. The downside to the ZC tranny is, cruising on the highway you'll be turning pretty high rpms so worse gas mileage. The best way to go is get a zc tranny and put in an Si final drive. You'll have the quickest acceleration with not as high rpms on the highway. Also, heres a cool site to tinker around with for trannies...
http://crx.honda-perf.org/math/index.html
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-27-2004, 08:22 AM
SiZ's Avatar
SiZ SiZ is offline
Re: tranny question
Just use an Si tranny!
Old 05-27-2004, 11:32 AM
1PhatCX's Avatar
Re: Re: tranny question
works for me!
if it is the dohc ZC tranny then i'll sell it, if its the Si, then i'll use it
how can I check to make sure its in good condition? its not in a car so i dont know if it has any grinds or not, what should i be looking for??
Old 05-28-2004, 11:32 PM
1PhatCX's Avatar
well, i picked up the tranny tonight and looked and saw the PL3/3000 on the side! so i gots myself an Si Tranny i'm pretty happy, should be going in next weekend, need 2 get the flywheel re-surfaced tho that i got with it
also, what should I check on the tranny? i noticed the motor mount looks different from the one I got, will it be a problem??
Old 05-29-2004, 01:07 AM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
Re: tranny question
just to clear up a few things.
the ZC has a 3.88 final, just like the DX. Si is 4.25.
a ZC transmission with a 4.25 final will be sitting at a higher rpm per gear than with the 3.88 final.
A ZC's gears are not shorter than an Si, they are closer. gear ratios determine how much the rpm drops between shifts and the final determines the "length" of the gear.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
