Headlight problem
OK it's a 99 Civic, in the past when I leftr my head lights on the little buzzer would go off when I open my door, it no longer does that. Also my lights on my gauge stopped lighting up, so I figure I blew some fuses, I dont have the fuse door which shows which fuse goes to what. Can anyone tell me what i need to fox to get these back? thanks
99 Civic EX Si Spoiler Type R mesh grill |
Re: Headlight problem
just get a fuse tester and run it over the fuse panel, and replace whatver might be bad. im not sure where you can get the real diagram other than a chilton's, haynes, or helms manual.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
yea I did that and found the bad fuse for the gauges but the headlight alert still does not work and all the fuses are OK from the best as I can see
then the sensor in the door could be bad, does your door still chime when you open it?
good question, I will check that next time I go outside, if that is the case is that hard to fix w/out a manual?
the door chime does not go off when I open the door
sounds like the sensor is bad then. you can either replace it, or wire up another reminder for your headlights like the one of www.teamdelsol.com go to information, how-to, then lights on reminder. up to you which you want to do.
the sensor in the door is easy to replace, it is just a button that any delaer should have in stock.
OK I will look into doing that, appreciate the help
