Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 05-11-2004, 03:10 PM
SYSCONX SYSCONX is offline
Exclamation 2001 Accord V Timing Belt
I just passed 90,000 miles on my car and will need to replace the timing belt soon. I read thru the manual and all it says is how to replace the belt. There is little mention of what to remove to get to the belt, ex. compressor, alternator... as well as the parts I will need to replace while replacing the belt, besides the water pump and the belt. Will I need to replace any seals? Is there a balancing belt? If someone knows the steps to get there, please reply. I need any help I can get.
Best Regards,
Kris
Old 05-12-2004, 09:00 PM
HONDA_99 HONDA_99 is offline
Re: 2001 Accord V Timing Belt
there is no balancer shaft belt, it's not I4. V6 doesn't need it.
use pictures out of my gallery. it's out of helm's manual (Honda)
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 05-13-2004, 09:28 PM
Just started doing the belt change. The removal of all the components to get to the belt is not that bad except for the covers. I was expecting to have a hard time with the crankshaft pulley, but that was just a minute job and a bit of pulling. Good thing I have a car for tomorrow to get to work, else I would have to work in the dark. I'm wondering what it will take to replace the water pump and the idler pulley. I removed the power steering pump and the side engine mount for easier access. I wanted to add some pictures but don't know how. I have a question. All the marks were on the dot except for the rear camshaft pulley off by 1/8", probably a tooth off. Or maybe it should be this way. I didn't have any problems so far with the way the engine runs. Should I be concerned and correct this? This is the first time the belt is replaced, or is it? The car was hit once, maybe the shop was in there and didn't install it exactly the way it should be. Like I said there was not problem with the enigne porformance. If anyone can please respond to my questions.
Till later,
Chris
