Go Back   Automotive Forums Car Chat > Oldsmobile > Alero
Old 06-11-2003, 06:09 PM
mike42 mike42 is offline
audio system
hi i have a question, do i have to do any mods, or have to install a special chip to install my audio system in my 2000 alero. i have 2 320 watt amps. 1 alpine eq, 15¨ sub and 1 sony car radio.
Old 04-01-2004, 09:29 AM
2002alero21 2002alero21 is offline
help
same question basically...does the stock CD player have the plugins to install an amp or do I need a new CD deck???
Old 04-15-2004, 04:56 PM
aboyle0203 aboyle0203 is offline
Re: help
you def. need a new deck. no RCA jacks on the factory head unit. they do however make a converter for about $15. you slpice into your speaker wire and then you can plug in rca jacks. the problem is you also amplify all your noise. i did it for a few months in my 2000 alero. i ended up buying a new head unit to run my orion 12s with. sounded much better
Old 04-15-2004, 05:03 PM
Re: audio system
no mods or chips required on my 2000 gls. the filler plate is kinda screwed up but it looks good when done. i installed a deeper cd player then cruthfield said i could. there was a need to cut a piece of the plastic in the back to fit it but it has been great for over a year. i used the wired adaptor kit from autozone and everything worked great no mods needed!
Old 05-10-2004, 11:03 AM
DamienZ28's Avatar
DamienZ28 DamienZ28 is offline
Re: audio system
ONE word "PIONEER" lol my fav OK I have one for you. Most are single din stereos GM uses Din1/2 and the aleros is double din correct!? Well I have a din1/2 the gm factory fit pioneer and i was wondering if anyone has seen a plate to mount this one or if ill have tomake one?
http://www.fiawtcc.com/
2006 BMW 330i| 2009 Mercury Mariner Premier
Old 05-10-2004, 03:10 PM
jamcllw jamcllw is offline
Re: audio system
I know 2000 Alero's are DIN and a 1/2 not a double DIN. I've completely replaced everything from the factory radio and speakers. I'm running Pioneer 4x6's, 6x9's and tweeters. I have 3 Audiobahn 12" subs in the trunk. With 3 Rockford amps running everything so I'm pretty sure you don't have to do any mods or special chips for it to work.
Old 05-10-2004, 09:34 PM
DamienZ28's Avatar
Re: audio system
Thanks for the info!
Old 05-27-2004, 11:55 AM
Half Breed Half Breed is offline
I have a 2000 GLS and i left the factory deck and hooked up 2 alpine type R and a v12 deck to the stock system, and honestly it sounds better then when i had my alpine deck. i would recommend that you leave the stock deck in. the only adapter you need is a line out converter. there around $20 at any electronics store.
