Go Back   Automotive Forums .com Car Chat > Honda > Prelude
Old 04-30-2004, 07:24 PM   #1
lotsofproblems
Send a message via AIM to lotsofproblems Send a message via Yahoo to lotsofproblems
starter problems?
every once and a while when i try to start my car it just dosent. when my key is in the on position all the dash lites up like it normally would but everyonce and a while when i turn the key to start the car all the dash just goes black and it wont start even though you can hear the starter spinning around. Ive replace the battery, altinator and starter. Im all out of ideas.
lotsofproblems is offline   Reply With Quote
Old 05-01-2004, 06:56 PM   #2
Bobiii84
Bobiii84's Avatar
Send a message via Yahoo to Bobiii84
Cool Hi
Have u checked to see if maybe a short is draining ur battery? Cuz other than that and what u have replaced theres not much to the ignition system. I guess u could check ur plugs, cap, etc. Don't replace yet though. I picked up a spark plug checker at a store for 2.99$ and it plugs in where the spark plug should go and blinks constantly if working correctly. Ok so basically the only others things that could have a problm other than what u fixed already are these things. Ignition coil[test with an ohmmeter], Ignition wires, plugs, distributor, rotor[ look at distributor cap and rotor to check for damage], Check ur fuses[ Do this first], and ur regulator. Good luck and let me know what happens!
Bobiii84 is offline   Reply With Quote
Old 05-01-2004, 10:13 PM   #3
crzyCollegeKid
Re: starter problems?
before you go out and buy a new starter, and run a full diagnostic, why don't you check out the switch that checks to make sure your clutching when starting. I *think* its called the neutral safety switch, and it costs like $33. ***IF*** it is broken, you can replace it....or bridge the circuit like some of my friends have done (lets you turn the car on without clutchin')
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
crzyCollegeKid is offline   Reply With Quote
