Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 01-14-2006, 09:56 AM   #1
hockeyguy
headlights out
This is a repost because I did not get a reply, so here we go again.
I have an 89 GP with no low beams, parking lights and high beams fine.I have mileage read out intermittently. This GP does not have day running lights. Fuses ok.
Could this be a bad control switch module or is there a resistor or relay??
Thanks for the help.
hockeyguy is offline   Reply With Quote
Old 01-14-2006, 12:18 PM   #2
richtazz
stupidity should hurt
richtazz's Avatar
Re: headlights out
I would check the dimmer switch to see if it's out of adjustment ( it won't allow the plunger to push it in far enough to turn on the low beams). It will move far enough to turn off teh hi-beams, but not to turn on the lows. the other real common problem is the multifunction switch that controls the turnsignals, cruise and such.
Old 01-14-2006, 05:31 PM   #3
hockeyguy
Re: Re: headlights out
How do you get the steering colum cover off?? So I can check out the turn signal switch.
