Old 04-16-2004, 10:22 AM   #1
FletchTrick
fuel pump/relay control circuit
Can anyone tell me where the fuel pump relay control circuit is located? To make a long story longer, the relay caused the ECM to fail (acidic goo) which fried the control circuit. Thanks in advance.
FletchTrick is offline   Reply With Quote
Old 04-16-2004, 07:45 PM   #2
ashah000
ashah000's Avatar
Send a message via AIM to ashah000
Re: fuel pump/relay control circuit
Its on the driver side in the engine bay. It is next to the brake fluid resivior. There should be two relays. I think its the left one.
If you have more than 2, its think it's still the left-most one.
For Sale 98 Eclipse GS, 5 spd
ashah000 is offline   Reply With Quote
Old 04-16-2004, 08:39 PM   #3
Talon007
Talon007's Avatar
Send a message via MSN to Talon007
The capacitors (caps) in the ECU leaked and fried the ECU, not the fuel pump relay
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Talon007 is offline   Reply With Quote
Old 04-17-2004, 11:19 AM   #4
FletchTrick
O.K. so the ECM fried itself. It has been replaced. So has the fuel pump relay. I have no fuel pump coming on. I beleive the ECM took out the fuel pump/relay CONTROL CIRCUIT? Can you please tell me what that is or where that is? When the new ECM was first hooked up the car started but won't now. It seems to be an intermitten problem. It's a 1990 1.8 liter. Am I on the right track even?
Old 04-17-2004, 01:52 PM   #5
Talon007
Talon007's Avatar
So the fuel pump does not come on at all? You could alwasy try the test circut.
http://members.shaw.ca/dsm.1000q/Eng...mptestconn.htm
Chris Clark
www.Talon007.com
Old 04-18-2004, 10:01 AM   #6
FletchTrick
The fuel pump only comes on intermittenly or when energized from the battery. Also, I can get a reading from the ECM on a voltmeter but only intermittenly as well.
Old 04-18-2004, 01:16 PM   #7
1stGenRocks
1stGenRocks's Avatar
Send a message via AIM to 1stGenRocks
i dont know if you have one or not but lots of newer cars have a auto shutoff that cuts power to the circuit if you're in a accident(g sensor) that could have fried too
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
1stGenRocks is offline   Reply With Quote
Old 04-18-2004, 11:51 PM   #8
Talon007
Talon007's Avatar
1G's do not have a pump shut off switch. The test circut is totaly independant than the regular circut, the only part the would have in common is the pump.
Chris Clark
www.Talon007.com
Old 04-19-2004, 11:02 AM   #9
FletchTrick
I am just going by this stupid manual. With the symptoms the car is having, it says either the fuel pump relay or it's control circuit is faulty. I know it's not the relay, there's a brand new one in there. So where is this "control circuit"? Or maybe it's something else? Any ideas?
