Old 03-31-2004, 01:01 AM
justlearning justlearning is offline
Send a message via AIM to justlearning
fan help im tired of this
oh my fan will not come on im gettin tired of messing w/ it and im about to install a switch some where on my console so i can manually switch it on and off because my car overheats very quick if any of u have done this and could tell me how to connect this i would appreciate it i have the 91 rs auto w/ a tbi... also would u recomend a different type of fan or thermostat to help this problem (one of a resonable price) rather than the stock factory one (plastic) in it now
Old 03-31-2004, 01:38 AM
mike123 mike123 is offline
Re: fan help im tired of this
well the fan isnt supose to kick in till 220 i believe i had this problem b4 but it was a lose connection
Old 03-31-2004, 11:47 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
look on the passenger side of the engine, there's a temp sensor in the head. unplug this sensor, turn the key to the on position, or start, and then touch this wire to ground. if the fan comes on, then it could be a bad temp sensor. if the fan doesn't come on then check the fuse, or it could be the relay, or the fan itself. summit sells a temp sensor that turns the fan on at a lower temp, i think it's about $20. the temp sensor in the front of the manifold does not controll the fan, just incase your confused
Old 03-31-2004, 04:36 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
I wired mine to the ignition coil, so I have no chance of it dicking out on me.
Old 03-31-2004, 06:11 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Re: fan help im tired of this
How has that treated you?? These electric fans werent designed to run constantly, I figured they'd burn out often if they're always running..
Old 03-31-2004, 06:33 PM
havn't had a problem yet, and I'm 60,000 miles into it.
Old 03-31-2004, 06:43 PM
DaMoNe6969's Avatar
I just put both my fans on switches.. Kind of a pain in the ass sometimes..
Old 03-31-2004, 06:44 PM
Yeah, I did that once, but it sucks when you forget to flip the switch on, or off for that matter, dead battery
Old 03-31-2004, 08:08 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
id go for the switch, if for nothing else other than you get to flip a switch. people like to flip switches, i think im going to develope a therapy where all you do is flip switches...
Old 03-31-2004, 08:12 PM
DaMoNe6969's Avatar
flipping switches can definatly be theraputic.. especially when driving!
Old 03-31-2004, 08:56 PM
Fit4Demolition Fit4Demolition is offline
Send a message via AIM to Fit4Demolition
i am having the same trouble. i just got back from advance auto and i got a thermostat switch. ME and my dad earlier tested the motor and it works fine and we also got a new relay switch today. My camaro is an 88, does anyone know where the thermo switch goes? Me and my dad cant find it. i hope the problem was the switch so i dont have to get anything else.
Old 03-31-2004, 09:27 PM
yeah i figured out my fan motor is burnt out and thats why it keeps melting the fuselink wire connected to my relay my part will be here tomorrow at 9 am and i also bought another thermostat this one is 160 degree instead of the 190 something i think they run factory but if neither of these help it will be that theraputic switch install
Old 03-31-2004, 09:34 PM
excellent
Old 03-31-2004, 10:26 PM
droptop94 droptop94 is offline
look under the hood for the relays they should be in a fuse box under a cover. swap you'r ac relay with you'r fan relay then see if your ac works. if it does then your relay is good. check all your fuses. then check the fan it's self. I would not hook up a togle switch. too easy to forget to turn on.check in to the temp sencor from summit or some auto parts store. make sure the kit has a relay. the fans will burn a switsh out over time with out a relay instaled. hopefully the new fan moter will work though.
Old 04-01-2004, 10:46 AM
anybody got any advice for me? i havent installed the new thermo switch yet but if that isnt it what else could it be? Will a Chilton manual help? I hope i have my fan working by tomorrow so i can finally drive it. if you know whats wrong can you help me figure it out?
PS: Are there two relay switches? i replaced one and found another later on. COuld that be it too?
