Old 03-27-2004, 06:04 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
Real difference between minime's?
I was thinking, and we all know what happens when we think....
How much of a power difference would there be between using a d15 block with a z6 head or a d16a block with a z6 head? Is the .1 liters a real big thing? also do different d16 blocks produce difference power with the same head on em? f/e a y8 (?) block with a z6 head (obd I on obdII block)?
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 03-28-2004, 03:40 AM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Re: Real difference between minime's?
I'm not sure if its a big difference with the .1 liter, but more of the fact that the 1.6l come with mpfi and a diff cam on the d16a6, i think.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 03-28-2004, 04:38 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
Re: Re: Real difference between minime's?
ya, the d16a6 does have a more aggresive cam then the 1.5 does, but that doesnt really have anything to do with the block. I am not possitive, but the blocks may have a difference in pistons, that is the only thing i can think of that might be different.
KoRnSaQ
Old 03-28-2004, 12:09 PM
JimCRX's Avatar
JimCRX JimCRX is offline
Bigger is better!
Old 03-28-2004, 12:29 PM
d16a6crx's Avatar
d16a6crx d16a6crx is offline
There would be diffent compression ratios due to the different blocks, plus d16a6 has a much stronger bottom end than that of the d15b2
1991 CRX Si
Looking for 88-91 Sedan or Hatch
Old 03-28-2004, 08:20 PM
PunkAlex's Avatar
So would it be worth the 150-200 bucks for a d16a to replace the d15 in a hatch std, if plans down the line include a minime conversion?
Old 03-29-2004, 12:37 AM
lilol89crx lilol89crx is offline
d series blocks carry the same 75mm pistons, difference is in the stroke. IMO want vtec go with a z6 or y8.
Old 03-29-2004, 04:07 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
1.5 and 1.6 out of 4g civ's have the same bore and same size piston its just the 1.6 has different stroke. and different compression, giving it more hp
Old 03-29-2004, 05:01 PM
actually the 1.5 piston pin is located 3mm higher than the 1.6. in reality u couldnt use 1.6 pistons in a 1.5 without modifyin rod length or deck height.
Old 03-29-2004, 06:05 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
1.5 pistons are flat tops. a d16z6 head will have higher compression if you put it on the 1.5L block. a destroked 1.6L (1.5L) has the ability to sustain revs better.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 03-29-2004, 06:24 PM
d16a6crx's Avatar
If you are going to bother doing a swap, just go with a full z6 or y8 swap (if you want SOHC VTEC) then you know what you've got
1991 CRX Si
