Old 03-20-2004, 07:18 PM   #1
dadymat
85' 4x4 checking transfer case
Ive got a 85 4x4 full size k5 long story but ill make short......my truck has custom headers and i cant put the front drive shaft in but i want to test the transfer case I was told the transfer case was in order... when I engage the ...4H...the indicator light comes on and i can see the knuckle spinning when someone else was driving it forwards and backwards and i was on the ground looking under the truck.....however i cant seem to put the shifter in the ...4L...position does that mean it doesnt work? or partially works ? or am I stupid? lol
is there better ways to test the transfer case?
dadymat is offline   Reply With Quote
Old 03-21-2004, 03:26 PM   #2
dumbplumber
Re: 85' 4x4 checking transfer case
Are you in either park or neutral when you try. that is what you have to do.
dumbplumber is offline   Reply With Quote
Old 03-21-2004, 04:50 PM   #3
dadymat
yes ive tried in neutral and park...itll go into high just not low
Old 03-24-2004, 12:46 PM   #4
dumbplumber
sometimes when you are in park and try to change the vehicle will roll forward just a little and put the transfer case in a bind try rocking the blazer back and forth while you try shifting it into 4low. Also if it hasn't been in 4 wheel for a while you might want to change fluid and add some seafoam.
Old 03-24-2004, 04:38 PM   #5
k-5_350
this might seem stupid but, did you pull the stick to the right a little and then down. Somtimes there REALLY stiff pull hard, I've had to shift some of the old ones with my feet.
k-5_350 is offline   Reply With Quote
Old 03-24-2004, 07:04 PM   #6
dadymat
yes i have been pulling to side and down, i havent tried rocking the truck though....I ve pulled hard as hell
Transfer Case Identification Project J10 General Discussion 2 03-26-2011 05:14 PM
1999 GMC Envoy Transfer case removal Bootsm Jimmy 0 12-05-2010 10:16 PM
89 K-5 with a tranny/transfer case problem curtisserrano 1969 - 1994 Full size 7 06-01-2010 09:14 AM
99 Silverado K1500 4x4 Z71 Transfer Case Price stick64 Silverado 1 07-17-2007 09:39 PM
4X4 Transfer Case Control Module Problems FirstJimmy Jimmy 4 01-25-2006 05:45 PM
