Old 02-13-2004, 05:10 PM   #1
ashah000
ashah000's Avatar
Send a message via AIM to ashah000
Unhappy Friday 13th = bad luck for my car
So, first, i was driving to school, and my radio wasn't working for some reason, then I went over a bump, and my car made a squeaking noise. (could not tell where it was coming from) I am guessing the suspension. And every single bump i went over made my car make the noise. There were a lot. And then on the way back from school it was magically gone. WTF. What could have been making the noise?
And if that was not enough, on my way back from school, the squeaking noise was gone, but there was another noise, my car started to make a squealing noise while i was accelerating, (it was not that loud, but it was there). The only thing I could think of was timing belt. But the previous owner said he replaced them at the 60,000 mile change and I am at 75k right now. He better of not been lying. I hope it is not the timing belt.
Thanks in advance
Now to go and figure out why my radio is not working.
For Sale 98 Eclipse GS, 5 spd
ashah000 is offline   Reply With Quote
Old 02-13-2004, 06:35 PM   #2
95eclipse-gsx
Re: Friday 13th = bad luck for my car
dont fuck with the timing belt it will fuck u back real hard... i am a victim of it thats all i can say...
95eclipse-gsx is offline   Reply With Quote
Old 02-13-2004, 10:13 PM   #3
duckydsp
duckydsp's Avatar
Damn, I'm not even driving my car today. I would like to give a shot out to my mom for letting me use her car though.
HOLLA!
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
duckydsp is offline   Reply With Quote
Old 02-14-2004, 12:17 AM   #4
EclipseDuDe
Try adjusting your power steering and alternator belt. Check them by pushing down on them... if you feel theyr loose adjust the tension by adjusting the screw. I had to do it a couple of weeks ago because it got cold here and made my alternator belt slip adn sqeek like crazy.
EclipseDuDe is offline   Reply With Quote
Old 02-14-2004, 07:08 AM   #5
kjewer1
AF - Advisor
Timing belt cant squeal or make other noises. It cant slip. Its a cog tooth type belt, not a v belt.
My car often will make strange noises, then magically stop. I decided years ago that I wasnt going to chase down every noise that I heard. I could never find them anyway, then they would go away on thier own. Now I just wait for the affected part to fall off, then there is no question about what I need to fix But you should get your ball joints checked anyway to be safe at least, and if they need replacement its free.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
kjewer1 is offline   Reply With Quote
Old 02-14-2004, 08:46 AM   #6
ashah000
ashah000's Avatar
I called the 800 number for mitsu yesterday, and they said the previous owner have the ball joints taken care of, but I am going to try and find out on monday if they just "inspected" them, or they actually replaced them.
BTW what are the symptoms of a messed up ball joint.
And is there any thing else that could squeal, while under acceleration.
Old 02-14-2004, 02:14 PM   #7
kjewer1
AF - Advisor
Also keep in mind that the replacement balljoints fail too Dont ask me how many I'v gone through. I keep a spare set in the garage. And since this is a safety recal, they have to replace them no matter how many times theyve done the recall. Now, if they have like 80k miles on them they can argue that its normal wear, and rightly so. But if they were done recently I would make them do it. But its a judgement call, and thats the tough part. Hopefully the mileage makes it a clear decision.
I'm assuming this is a 2g. To test you need the car off the ground, so you can lift the tire striaght up, but still see the ball joint. Its on the straight lower control arm, called the Lower Laterall Link, and is attached to the sprindle, jsut inside of the tire/wheel. Have some one pry or lift the wheel while you watch. If you can see the gap between teh arm and spindle chaging (the rubber boot will make it obvious too) its way out of spec. The dealer has to measure with a dial indicator to check, so it may not be this obvious. But I find that by the time you can notice they are bad, you can see it.
As for the squealing, I would suspect any of the v belts. AC, PS, or the alternator/waterpump (which also drives the PS). For the NT cars, I dont know how the belts are setup, but it will be a v belt thats squealing. Bad baerings in an accessory can also squeal.
Kevin Jewer
Old 02-14-2004, 02:28 PM   #8
ashah000
ashah000's Avatar
If i goto satan do they have to look at them for free
Old 02-28-2004, 04:04 PM   #9
RiceRocket18
RiceRocket18's Avatar
Send a message via AIM to RiceRocket18
WOW!!!.. it's good that you guys brought it up. cause i've been having exactly .. well.. not sure if it's exactly.. but same kinda squealing sound. it only happens whenever i acelerate up and over 4000RPM. it's a very high pitch sqealing sound and not too loud but still noticible. i've had my car inspected regularly at the mod shop.. and gues they never found anything unusual. maybe because i never brought it up? i've always thought that it could just be some friction between the belts so nothing to worry about.. but now that more than one of you brought it up i am starting to worry.. should i mention that to my mech and have him checked next time i go in?.
i just went to the DSM dealer today and turned out that fuckers wanted me to make an appointment to replace the damn ball joint. so i am going in on tuesday. hope that they don't fuck around with anything else other than replacing that damn defective design ball joint shit!!
RiceRocket18 is offline   Reply With Quote
Old 02-29-2004, 02:07 AM   #10
RiceRocket18
so nobody has ANY idea what so ever on why it makes that sqealing sound?
Old 03-01-2004, 01:25 PM   #11
anarchy1114
anarchy1114's Avatar
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
rice rocket check your ps , ac and alternetor belt. if its loose tighten it up. i ignored my sweakin and my car got pissed of and decided to throw the belt. oh well. but tighten ur belt up and the sweakin should go away and if it doesn't turn up the music and try to ignore it till u can actually tell a part is defective or falls out , blows up, ur power steering goes out and the like. again thas jus my
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
anarchy1114 is offline   Reply With Quote
Old 03-01-2004, 04:24 PM   #12
RiceRocket18
LOL.... great recommandation.. i'll just have my mech check that out next time i go in for an oil change.
TEAM FFM HONDA GP 125 CESKE REPUBLIKY - BRNO BAD LUCK FOR MIKE DI ... - FFMoto.org Automotive News Automotive News Desk 0 07-08-2006 07:10 AM
Brother has bad luck with cars. 2strokebloke Stress Release 3 02-16-2004 12:54 PM
