| Let's get Technical! Discussion for hardcore in-depth motor heads! |
ecu for sohc zc vtec
I have a 95 civic ex with a sohc zc vtec in it.i just read on another forum that there might be an upgraded ecu to use for this engine,the si.is this true and does anyone know where i can find specs for my engine cuz my valves are ticking like a mofo
Re: ecu for sohc zc vtec
No, your valves have nothing to do with your ecu. And you should be running a p28 ecu to begin with..that ecu is the one you would want to run. Good luck and try to get a valve job done!!
and dumping the ZC won't hurt either get a SOHC vtec or a b18b for cheap. all i've ever heard or seen is bad things with SOHC ZCs
i had one of them sohc zc vtecs, i had NO problems with mine. try adjusting your valve lash . another ecu u can try is the P08 from a 1.5L vti D15B sohc vtec- had a wilder cam
i got 1
would the p28 ecu work with a D15b sohc vtec in a 91 lx?
