Old 02-01-2004, 07:46 PM
krcl852 krcl852 is offline
cold air intake
I am looking for a cold air intake system for my 1988 LeBaron but have not found one. What is a good system at a reasonable price?
Old 02-01-2004, 10:14 PM
454Casull 454Casull is offline
Re: cold air intake
You could fabricate your own.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 02-02-2004, 06:38 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: cold air intake
doubtfull you will find an aftermarket one for that car.
best bet is to buy one for a similar engine and modify.
Mustangs are nice, but I'd rather have one of these...
Old 02-02-2004, 05:36 PM
From what type of engine should I get it? And about how much would it cost? My car is an 88 with a 2.5L 4cyl.
Old 02-02-2004, 09:39 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: cold air intake
i would go with the fabrication route, 3 or 4 inch pvc and a nice filter of some sort, go to a plumbing supply place and get the elbows you may need. thats just my 2 cents tho. why spend all that money on something you are gunna have to cut and hack anyway?
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 02-03-2004, 03:43 PM
I'm not sure ow to make my own that's the problem. How difficult is it? What would I need?
Old 02-03-2004, 05:28 PM
Re: cold air intake
Some pipe sized for your needs and a hacksaw. ABS/PVC cement, depending on what pipe you use, if plastic.
Old 02-03-2004, 05:59 PM
Re: cold air intake
How much of a differnece is there in performance if you fabricate your own compared to buying one.
Old 02-03-2004, 09:16 PM
cvcc_wagon's Avatar
Re: cold air intake
probally not much. a performance intake does not make a huge differance on an unmodified engine, as long as you have no flow restrictions and a good filter (K&N or whatever) you should be alright
Old 02-09-2004, 08:22 PM
Re: cold air intake
Do you think it is worth the cost to buy one? Or will it make such a small differnece its not even worth buying it.
Old 02-13-2004, 02:18 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
It is likely you will not notice the difference.
Beer tastes better upside down.
Old 02-15-2004, 05:09 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
A Cold Air Intake works are follows: You get a 1% gain in HP for every 11.1 degree's you lower the intake temperature. This is because Cold Air is more dense than warm air, which basically means more air molecules are in the same space, to put it simply. If your motor is 250HP and the underhood temp is 110 degree's and the outside temp is 70 degreess, that's a difference of 40 degrees. That comes to a 3.6% gain in HP, or 9HP (in this example). I hope that explains a little the principle on how and why a CAI works.
