Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 11-14-2004, 06:49 PM
kegroening kegroening is offline
No heat
I have a 1989 b2200 truck.The radiator and thermostat are both new.Temp runs in the lower 1/4 of gauge.
when I switch to the heater,i get no heat,not even warm,seems like air is ambient temp.no matter what setting on slide controls i get cold air. Please help winter is coming on.
thanks
Old 11-15-2004, 05:18 PM
zipcom zipcom is offline
Re: No heat
thanks
this happened to mine. it turned out that it was the cable that ran to the themastat dial on the dash broke. It you look behind the dash and move the dial back and forth you can see which pulley it goes to. You can easily move it manually and see if you get heat.
I was unable to find a source to replace mine. if this turns out to be your problem and you find a replacement, let me know!
Kipp
