Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 01-16-2004, 02:23 PM
mrsyeltzin's Avatar
mrsyeltzin mrsyeltzin is offline
92 accord suspension
im thinking of getting the eibach pro kit for my 92 accord ex. the springs will lower the car 1.2 inches. What struts should i get so i can have a smooth ride? thanks.
Old 01-16-2004, 07:40 PM
BullShifter's Avatar
BullShifter BullShifter is offline
Re: 92 accord suspension
You mean a smoother ride, there is no such thing a smooth ride on lowering springs because the springs are stiffer. If you can afford adjustable struts, those would be first choice - Koni Yellow, Tokico Illumina, KYB AGX for non-adjustable struts - Koni Red, Tokico HP, Bilstein.
Old 01-16-2004, 08:48 PM
whyte Gsr b0i's Avatar
whyte Gsr b0i whyte Gsr b0i is offline
Send a message via AIM to whyte Gsr b0i
yeahs if you are gonna go eibach the Koni yellow's are a nice match also the Koni red's
Old 01-18-2004, 05:41 PM
mrsyeltzin's Avatar
so would the adjustable struts be smoother than the lowering springs?
Old 01-18-2004, 08:01 PM
Adjustable struts allow for tuning of ride stiff or soft using stock or lowering springs. I don't exactly understand your question . . . Springs lower . . .shocks/struts control springs . . . both required.
Old 01-18-2004, 11:21 PM
mrsyeltzin's Avatar
okay now i get it, that the adjustable struts will just control the stiffness or softness of the ride, but the springs are the actual lowering factors. Makes sense, thanks.
Old 01-18-2004, 11:58 PM
Right, now if you went with something like Koni yellow struts, there is an actual adjustable spring perch(change ride height 25mm max)
'95 Accord suspension question? antoniyen Accord/TSX/Accord Hybrid 4 01-08-2010 09:09 AM
accord suspension carolinacamelkille Accord/TSX/Accord Hybrid 0 04-23-2007 07:15 PM
95' Accord suspension questions FadingSunlight Wheels/Tires/Suspension 4 03-11-2006 02:03 PM
Accord Suspension Chez_Bippy Wheels/Tires/Suspension 1 03-29-2005 12:20 AM
1st Gen Oddy/Accord Suspension dblair Odyssey 0 08-11-2004 09:43 AM
