Old 01-30-2002, 06:33 PM
Jarflow Jarflow is offline
Send a message via ICQ to Jarflow Send a message via AIM to Jarflow
Easiest way to run under under 13's in a civic
In a 3g civic
what motor and mods would you recommend and try to keep the budget under 6 grand
My car is like my own personal universe, shes my drug and it only takes twelve bucks to fill her up, but in my galaxy there aint no room for earth, so im leaving it cause i can feel the oil pressure building up, turning over thee ignition of my solar system, check the gauges, push in the tape, put my foot on the brake, shift exsistance, light my ciggarette and take it state to state until i crash into my fate
Old 01-30-2002, 07:42 PM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
I don't know if you can get a Civic under 13 seconds with 6K. It would also depend on what model Civic you have. If you have an engine that produces low hp, I say go b18c5. But before anyone answers any questions we need to know what model it is.
AF Nordic Crew #3
Old 01-30-2002, 07:58 PM
3rd gen
Old 01-30-2002, 08:08 PM
b18b1 = 1400$
b18c1 = 3100$
b18c5 = 4200$ estimate
whats the hp diffecence in a b1 and a c5
like 50 or 60 hp
Old 01-30-2002, 09:31 PM
Someguy Someguy is offline
Send a message via AIM to Someguy
But then you probably still need to either loose a lot of weight or gain quite a bit more power (more then typical bolt-ons) or some combination of both. The B18B is rated at 140 hp if I remember correctly and the B18C5 195 hp.
Old 01-30-2002, 09:38 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
beef up the internals and run a 500 shot of nitrous
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 01-30-2002, 10:31 PM
Kaneto's Avatar
Kaneto Kaneto is offline
Send a message via AIM to Kaneto
Well, the third gen (85-87) weighs something like 1900lbs stock tops (depending on the trim and specific year). Strip it down and it'll be even lighter. That's your biggest advantage.
Your biggest disadvantage is the engine bay is a little small, and swaps are complicated. So the question is are you doing the work yourself, or having it professionally done.
Getting the swap done professionally is going to eat up your money pretty quick. It'll be pretty tough to get 13s reliably for 6 grand. If you have the tools and know-how to do it (mostly) yourself, go with a b16a turbo. The b16a swaps into a 3rd gen a lot easier than the b18s. The engine bay is rather small... even with the b16 you have to bang a dent into the driver's side frame rail to clear. The b16 is also considerably cheaper. With the turbo and good tuning, 13s are easy. Shoot for 11s.
Old 01-31-2002, 03:37 AM
exospeedAMcrx exospeedAMcrx is offline
Send a message via AIM to exospeedAMcrx
With 6K, you can get a Civic into the 12's.
I'd like to list the whole thing. but check out an example on my page.
www.exospeed.com
the webstore has a list of a complete swap. has everything you need to swap and its a formula for a high12 to low 13 sec car.
Wil
Old 01-31-2002, 05:48 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
trade it in for a Z28SS, WS-6, or Firehawk SLP.
Old 01-31-2002, 06:16 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Swap in a JDM ZC. cost of engine and 5sp about $1,000
If the car is carbed then you need to convert to Fuelinjection. say about $500 fuel pump and lines, plus some wiring for the ECU.
This should get you into the high 15s low 16s with I/H/E
For about $2-3,000 you can add a Turbo kit.
This will take you well into the 14s, and well tuned should push you into the 13s. But you would need to worry about suspension and brakes etc, would might soak up a another couple of grand.
As well as possibly rebuilding the engine with lower CR pistons etc. Thats another easy $2,000
If you want someone else to do the work for you then double all the prices.
