Old 12-25-2003, 10:48 AM
oceanrunnner oceanrunnner is offline
2000 Suburban electrical Windows
I have a 2000 Suburban with eletrical windows. The front windows both driver and passenger works fine. The passenger and driver's side rear windows doesn't work. How can I correct the problem and what is the problem(s) with the windows. Is there a recall on this problem
Old 12-26-2003, 07:35 AM
jfmctlaw jfmctlaw is offline
Re: 2000 Suburban electrical Windows
go to Chilton's web site and find the schematic for your truck. It could be a switch, harness, motor.
Somone else (sorry, i forget who) posted this site. I found it pretty useful.
http://www.cybrrpartspro.com/Manual%...delLookup.html
Old 12-27-2003, 08:06 PM
99ssconv 99ssconv is offline
Rear Door Window Inoperative (Replace Affected Motor/Inspect Opposite Motor)
2000-2001 Chevrolet and GMC C/K Utility and Crew Cab Pickup Models
This bulletin is being revised to change Correction information and add warranty information. Please discard Corporate Bulletin Number 00-08-64-018B (Section 08 -- Body and Accessories).
Condition
Some customers may comment that the rear door window is inoperative.
Correction
Replace the affected window motor. Refer to the Window Regulator Motor Replacement procedure (SI Document ID #768004). Inspect the other side following the procedure below.
Partially remove the door water deflector. Refer to the Water Deflector Replacement - Rear Door procedure (SI Document ID #764430).
Look at the motor with a mirror. If the motor is marked with the designation "Rev III" , do not replace the motor. If the motor has any other designation, replace the motor.
Parts Information
Part Number
Description
88937199
Motor Asm, RR S/D WDO Reg (LH)
88937200
Motor Asm, RR S/D WDO Reg (RH)
Parts are currently available from GMSPO.
Old 02-06-2004, 12:10 AM
2000BurbOwner 2000BurbOwner is offline
Send a message via MSN to 2000BurbOwner
I also have a 2000 Suburban with the exact same problem. The front windows work fine but the back windows don't. Did you get this resolved yet? I haven't been able to find any information on this yet. Thanks
Old 02-06-2004, 09:12 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: 2000 Suburban electrical Windows
Follow the procedure outlined in the post by 99ssconv...Fixed everyone I have seen
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 02-07-2004, 12:14 AM
Re: Re: Re: 2000 Suburban electrical Windows
So you suggest replacing BOTH motors in the rear windows? Isn't it odd that we both have the same exact problem that both the rear windows don't work and not just one or the other? Is there something in common to both windows?
Old 02-14-2004, 09:07 PM
GNW GNW is offline
Okay one more GM Tech on this tread!! Experience says "regular use on pwoer window motors will keep them healthy." Let's explain, the window motor uses brushes that ride on a surface of the armature called the commutator. The commutator is copper. Copper corrodes. A light film between the commutator and the brushes will keep the motor from working. These guys know of the bulletin put out by GM and so do I. Here is another idea to get the motors working again without taking anything apart or buying anything. Startup the vehicle, make sure the window lockout is off, get in the back seat, and with the door open push down the window switch. Next, shut the door firmly while holding the switch down. You may have to do this 2 or 3 times. Most of the times that I have done this the windows start to work. You may need to go as far as to remove the door panel (lifts off on this one) one tap on the motor area when holding the switch in the down position. If you get the windows working again, use them at least twice a week. Shutting the door firmly makes the internal parts of the motor vibrate and in turn holding the switch at the same time can cause a temp connection that will start the motor moving. I have used this to diagnose several types of cars.
Old 02-21-2004, 07:30 PM
spruce spruce is offline
How do you get the rear door panel off of a 2001 Suburban?
Old 02-27-2004, 04:23 PM
Thank you very much! I had to remove the back panels and tap on the motor and they started working again. They have both since stopped working so I purchased new motors. Thanks for your help!
Old 02-27-2004, 04:25 PM
If the 2001 is the same as a 2000, then there are 3 screws. One at the bottom right hand of the panel, one near the door handle and one up by the lock. You may need to check these locations for accuracy. If you remove these 3 screws, and the lock cover plate, then you can lift up on the panel and remove it. It's a lift-off style panel. very easy to do.
Old 02-27-2004, 04:28 PM
Oops, sorry, not lock cover plate but the window switch cover plate needs to be removed. Then easily remove the window switch and push it through after you lift off the panel.
Old 02-27-2004, 05:07 PM
again, you were right! i shan't question your replies again your wizardness....hehe : )
