Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-19-2006, 03:26 PM
tko tko is offline
problems with my 91 caprice
its not in the best condition in the world but it still runs good with 197,000 miles i need a little work done to it but i can figure out what it is there is a seal at the back of my motor leaking kind of heavy but i cant tell were it is coming from any methods on finding that and i have this problem where the motor or something around the motor clicks after the car stop accelerating all the way to an idle
Old 02-19-2006, 08:37 PM
CapriceCop CapriceCop is offline
Re: problems with my 91 caprice
Question. What size motor does your car have? Mine has the 350 5.7L and I had a similar problem a couple years back that turned out to be the oil pressure sending unit on the back right side of the engine. It seems that I have a high pressure oil pump (over 60psi even hot) and it will blow them out after some time. Hopefully that is the problem. If not that seal, how good are your valve cover gaskets or the intake manifold gasket? Definitely easier to fix.
The clicking thing is hard to diagnose but I have an issue where my back exhaust manifold bolt on the right side will back itself out over some time. The last owner decided to put antiseize on the bolt to keep it from sticking ever again. Apparently it works .
Best of luck.
Keith
