Old 08-17-2002, 02:12 PM
CivicDude98 CivicDude98 is offline
air intake question
I have a 98 civic ex.
I installed a generic air ram intake which i bought from ebay a while ago.
My cousin helped me install it. My question is when he installed it, only the o2 sensor was hooked up to the intake. Buth there were other hoses
that were hooked up somewhere to the stock intake. Is it ok to leave these hoses hanging and not used? I don't want to damage anything.
I think these are breather hoses.
Old 08-17-2002, 05:08 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
You probably should at least get some breather filters for the hanging hoses. They are not recieveing Filtered air the way they are now and filtered air is always better.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 08-17-2002, 06:29 PM
strodda strodda is offline
do you have a pic? unless im misunderstanding there isnt an oxygen sensor attached the intake(on accords anyways). on stock, there's the hose to the crankcase, and another that goes to the air boost valve(as stated by aem's instructions)
when i installed my intake the problem i first had was that there was a plastic tube that went from the stock box out to behind the headlight, which contained the valve, controlling temp and flow of air into the stock box.
heres what i did. i put the hose to the crankcase(breather), then i capped the other two. the left was coming from the air control valve near the headlight. and the right i capped with a filter. that used to come from the other tiny tube from the stock intake.
Old 08-17-2002, 09:04 PM
oh wait i made a mistake. So far the o2 sensor is hooked up the intake
and the blue hose that came along with this intake is hooked up to the intake to the engine. Then there is this hose which doesn't connect to anything, this hose has two ends that are open to air. It's just stuck to another hose parallel to it. I think it's glued together. I can't tell if these two hose that are stuck together has an opening where these two hoses connect. If it does have an opening then, i guess i have to buy a breather filter. But if it doesn't have an opening then no harm done right?
Old 08-17-2002, 10:44 PM
where did this extra hosecome from? it cant be connected to nothing or else it wouldnt be there in the first place. can you get a pic by chance?? thatd make it alot easier
Old 08-17-2002, 11:32 PM
sorry i dun have digital camera now
Old 08-18-2002, 12:03 AM
stradda i think that extra black hose is the hose that was connected to my stock air intake box to the engine. Since they provided me with a blue hose when i bought the intake, i used this one instead. What u think?
Old 08-18-2002, 02:07 AM
oh, was one of those two hoses that are "stuck" together originally going from the intake to the engine? and the other goes under the pgm-fi(fuel injection-the thing in the pic)
if thats right, it doesnt matter, just leave it how it is. the hose that is still being used has coolant in it, so dont mess with it.
Old 08-18-2002, 01:57 PM
thanks for helping strodda
Old 08-18-2002, 07:29 PM
np. thats what we're here for
Old 08-29-2002, 01:52 AM
BullShifter's Avatar
BullShifter BullShifter is offline
O2 sensor on an intake?
Old 08-30-2002, 02:04 AM
Tominos Tominos is offline
the sensor is the air temp sensor right? then there is a hose that connects from the intake to the valve cover. if you don't have a hole for that on the intake, just buy a breather filter and put it on the valve cover. as for the two tubes, i know exactly what u are talking about, all 6th gen sohc civics have those. it is two tubes, one that connected the stock vacuum hose from intake to valve cover, the other connects the coolant from throttle body to block.
Old 11-27-2003, 01:18 PM
celtic celtic is offline
hey man couldn't help but read over what you guys were saying... i'm in a similar predicament, i just went to put an hks filter on my rsx and there was an additional hose that went to the top of this box i had to take off, i'm pretty sure it goes to the crank case.... is there a filter that you can buy to put on there or something? it looks dumb sitting there out in the wind.
cheers
Old 11-30-2003, 01:15 AM
SOHCD16y8 SOHCD16y8 is offline
Re: air intake question
it is fine how it is the open tube was used for a breather on the stock inake. Leave the other line though because radiator fluid runs through that to heat the throttle body
Old 12-03-2003, 03:07 AM
cuba3377's Avatar
cuba3377 cuba3377 is offline
lol
O2 sensors go on the exaust manifold.
u probably mean the mass air flow sensor.
BTW, the extra hose goes to the pcv
(positive crankcase ventilation) valve on top of your valve cover. all it does is recycle air.
94 INTEGRA NEVER LOOKED SO GOOD ^^
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 04:48 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 07:11 PM
Important Cold Air Intake Question Accord4u2nv Accord/TSX/Accord Hybrid 5 02-06-2002 02:47 PM
Air Intake Question.... kicker1_solo Engineering/ Technical 14 01-09-2002 03:39 PM
air intake question SkylinesKillAll Engine 18 04-27-2001 09:51 AM
