Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Old 12-11-2003, 12:29 AM
dull_machete dull_machete is offline
Send a message via AIM to dull_machete
Smile about to buy this gsx....
http://toritzie.tripod.com/forsale10...ieclipsegsxawd
can someone tell me what i should look for when i check out this car? i know nothing about cars so a bunch of info will be greatly appreciated!
and is this car most likely a stick??? i just emailed the guy and am waiting for his reply.
Old 12-11-2003, 12:51 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
actually as far as i remember is more common for it to be an auto but who know, just wait for the guy to email you back and you will find out...
and when you go and look at it, find out if it has had any engine problems, if i were you i would go on car fax since he the vin # is right on the page and look up the car, i believe that will even tell you if its a stick but i am not sure... good luck, looks nice!
Old 12-11-2003, 09:36 AM
nhockett nhockett is offline
Re: about to buy this gsx....
Do you have a trusted mechanic? You might think about paying someone who knows about cars to check this out. Someone did that to a car I was selling one time and honestly they found all kinds of things. It was a $1500 truck so ... Sounds like it would be a good reliable vehicle. Timing belts were changed. Do they have reciepts for the work they've done. Clutch work? How are the brakes? Then there's crankwalk. I don't understand how this starts but it ruins engines and you can locate it if it is there by a simple measurement. In the past when I have bought cars- most were high milage, older vehicles- I knew when I talked to the sellers whether or not they took care of it. Good luck.
Old 12-11-2003, 10:10 AM
Kaleco Kaleco is offline
Send a message via AIM to Kaleco
isn't crankwalk'n only common on the 2g DSM cars...i thought 1g had valve seal problems and timing belt problems but im not positive on this information can anyone post if that is wrong or not juss my thougts....
when look'n at the car check turbo make sure no oil leaks into intercooler pipe takes 2 seconds to check...than when ur running the car let the car run for like 15 minutes after it is warm'd up than drive the car...because there might be white smoke coming from the exhause...this could be due to Valve seals or turbo oil leak...also another thing to check is make sure the car don't burn oil...take ur finger and rub the inside of the tailpipe...if it has an oil feel to the grim than most likely the car burns oil...this is all little problems that the car might have but passing inspection will be a bitch and later on you might have more problems....of course check all the stupid little things too like windows doors...speakers...unless you don't care about any of that, juss remember stay calm and don't rush u need to take ur time buying a car is a big thing
Old 12-11-2003, 01:32 PM
Kaleco- It is more often a problem on 2gs which have the 7 bolt engine. I believe some 93 and 94 engines also were 7 bolt. His 97 most likely has the 7 bolt motor. It seems to be rare and I've never personally had this problem. Can you start a post explaining what timing belt issues are you talking about on 1gs?
Old 12-11-2003, 06:24 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
It is most likely a manual (I THINK), if you look at the engine picture you can see the little white reservoir (all the way in the upper right corner), that is the clutch fluid.
The car looks real nice.
For Sale 98 Eclipse GS, 5 spd
Old 12-11-2003, 11:15 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
are insurance rates for your company not higher for a bad title?
