Old 11-24-2003, 02:57 PM
cjevans cjevans is offline
Unhappy Service Engine Soon
My 1999 Suburban 1500 service engine soon light comes on when i am climbing up hill at a constant speed. it generally resets itself about 1 day later. Does anyone have some help for me?
Old 11-25-2003, 05:20 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Service Engine Soon
When the PCM sees a problem with the emissions system or its componants..it sets a trouble code and turns on the MIL (SES light)...If you can pull the code (some auto parts stores will do this for free) we can give you some ideas on what is going on
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-27-2003, 12:15 AM
gtcali gtcali is offline
I've heard you can jump some connectors at the bottom of the dash to get a code. Is this true? I got a constant 'Service Engine Soon' light yesterday.
2000 Suburban.
Old 12-01-2003, 05:19 PM
that is true, you can pull the codes from under thedash on the drivers side. My problem has been corrected, came out with 2 misfires from injectors 3 and 5.
Old 12-02-2003, 09:29 AM
dirty dan dirty dan is offline
'99 has OBD2 diagnostics and you can't pull a code simply by grounding the aldl terminals like the older GM's. It requires an OBD2 code scanner. Autozone normally will read your codes for free. Let us know what it says before you go buying any parts.
Old 12-03-2003, 01:50 AM
I bought an ODBII scanner. I was told by Kragen that a parts store got sued because they misdiagnosed a problem so they dont check codes anymore. Anyways I got mine on sale for 129.99 + a $30 rebate. So pretty much $100. Is that a good price?
ANYWAYS.... I got a P0446 Code - Evaporative Emnissions Control System Vent Malfunction.
Ummm...Any help on this. I went off roading in some dunes a couple of days before I got the SES light.
2000 Suburban 4x4 lifted
1989 Civic Sedan Mut Motor Turbo
1985 CRX Si Free - Project Car
1965 Chevelle SS - Some Day Project car (twin turbo V-8??!!)
Old 12-03-2003, 06:35 AM
jfmctlaw jfmctlaw is offline
Absolutely everything can and will cause a check engine light or SES light. From a loose gas cap (computer sees a pressure loss in the fuel tank) to a bad sensor or a bad computer (one that has no ability to make things happen or see fault codes the tech creates) , to a vacuum leak, a bad fuel pump, a bad spark plug, a plugged fuel filter or a broken, pinched or disconnected wire.
So when your check engine light or SES light comes on, the procedure is the same for all cars. Someone needs to pull the code, check the circuit, test a few sensors, see what’s going on and determine what it is the computer is really seeing and why it doesn’t like what it sees. I typically use a scanner to perform many of these tasks and the scanner will allow me to watch what’s going on. It will allow me to see what the coolant sensor, speed sensor, throttle position sensor is telling the computer. So as I watch the serial stream data, I should know if it is right or not. For instance, if I knew the engine was warmed up but I saw the coolant sensor was telling the computer the engine temperature was -40, I would know the connection at the coolant sensor was defective or the sensor was open. If I saw the coolant sensor was telling the computer the engine was 150F and I knew it was well over 220F, I would replace the sensor, clear the code and test drive the car to see if the code reset or the SES light came back on.
service engine soon ===engine code P0171 Mram76 Off-Topic 2 12-01-2012 06:20 PM
Service Engine Soon/service Vehicle Soon Lights ECSimmons1204 Grand AM 3 09-19-2007 06:50 AM
Service Engine soon, Service Vehicle Soon. Kidlex01 Grand AM 1 03-03-2005 07:29 PM
89 camaro engine trouble...service engine soon light Cbballplaya Camaro Discussions 17 10-24-2004 04:02 PM
Service Engine Soon Light and Service Light bowmanslandscaping SC/SL/SW 3 05-03-2003 02:43 PM
