Old 11-27-2003, 03:05 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Whats wrong with my D16a6 motor??? Rings or valves?
I need some tech heads on this one..Ok well my motor just broke 10,000 miles, It was FULLY rebuilt Nov. of 2002 last year. A couple months ago I did a compression test on the motor..240 psi on #1,3,4 cylinders cept for #2 cylinder with only 150psi!! Thats almost 100psi loss!. Now I am wondering how this could of happened, I have milled the head,honed bores, decked the block, 3 angle valve job,new pistons/rings,hot tanked head/block+++more...there should in no way be some kind of a leak happening.
I am pointing my fingers at the rings or valves. My car is only doing 15-20mpg and it seems to be getting slower as time passes. It doesnt smoke, but burns very little oil(rings?). Altough the motor purrs like a kitten with smooth idle. Now how can I tell if a valve is stuck open? I don't believe that bad piston rings can create such a big loss on compression but i do believe that a open valve can. Is there a way I can do a at-home leak down test?? I need to get this fixed as soon as possible.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 11-27-2003, 03:20 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Whats wrong with my D16a6 motor??? Rings or valves?
Your chilton will tell you how to do a leakdown test, to determine if it is valves, seals, rings, etc.
Old 11-27-2003, 08:25 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Re: Re: Whats wrong with my D16a6 motor??? Rings or valves?
the valves could possibly be out of adjustment.
Old 11-28-2003, 12:45 AM
cot's Avatar
cot cot is offline
If you do another compression test, you can try the bad cylinder dry, then squirt a bit of motor oil down into the bad cynlinder via the spark plug hole, then try it again.
If it's the rings, the oil should drip down and help temporarily seal them better, and the compression should go up noticeably for a little while. If it's the valves, obviously it shouldn't change.
An easy and quick thing to try
Old 11-28-2003, 11:18 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
If you had a valve stuck open, wouldn't your piston hit it? It seems like that would be an obvious problem...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-28-2003, 11:30 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
the valve wouldn't be stuck all the way open, just enough to not get a good seal. In most cases that i have seen though, a stuck valve would register 0 compression.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
