DRL or auto headlights?
I'm trying to make it so the only way to turn on my headlights is to use the switch. i've tried the whole resistor-in-place-of-the-sensor thing. my RPO code says that i have DRL and i have all the relays in my fuse block, but they don't come on until i let out the parking brake. my truck is a 98 4-cyl 5spd, and the lights that come on are my low beams.
thanks for any replies, -kyle
![]() 01 dodge stratus R/T 3.0L v6 5spd underdrive crank pulley, Eibach Sportlines Fidanza stage 3 clutch, Fidanza lightweight flywheel NO MUFFLER http://s72.photobucket.com/albums/i1...mperfixed2.jpg R.I.P. 12/19/05 '98 s-10 2.2L 5spd daily driver 2/3" drop, K&N filter Pacesetter header high-flow metallic cat. flowmaster 40 series BFG G-Force T/A KD's |
Re: DRL or auto headlights?
to turn off drl you need to bend a prong in the fuse pannel under the hood, ill go look when i get a moment and tell you the location and tab number, the resistor in dash turns off the automatic night time lights
okay, that makes sense, but i've tried the whole resistor thing and it didn't do a damn thing
BTW- i checked out your link to your cardomain page, and i wanna know where you got that body kit from. the only ones that i can find are Xenon and Wings West and i dont like either of those
FAST |
nob. IF it does you should turn on the switch as you were going to start it but just turn were gauges and stuff come on and push the button 4 times in a 8 to 10 second span.then you here the buzzer like you left your lights on then it should be on manual. you can turn them on and off Ok if dash doesnt have the little button by the way the button is the one for the dome light off or on but not the one that rolls that you can dim your dash lights with but the one that if you have the door open and the lights are on you push to turn off.If there is no button then you should have a fuse for drl thats in the fuse box on driver side at end of dash close to the door .if these things dont work just look in owners manual
FAST |
body kit came from e bay... i can look up the name of the seller if you would like, hes an e business
tracy, you mean the dome override button? i just went outside and tried it . nothin happened .
brisket, please do, i've been looking for something other than the rice-lookin ones
Re: Re: DRL or auto headlights?
the override button 4 times real fast and the ding noise will sound maybe a couple times.the noise that sounds like you left your lights on. Did you check to see if you had a fuse in the panel.Does your truck have the small senser on the passenger side on the speaker cover on the dash.
FAST |
Re: Re: Re: DRL or auto headlights?
FAST |
Re: Re: Re: Re: DRL or auto headlights?
I have not heard anything from you. I was just wondering if you got your drl to go off .If you did thats great i dont know if what i told you worked but i tried to help.That is what i done on my 2000 s-10 blazer .Well if you get a chance let me know how it turned out. Good luck dude with whatever you do
FAST |
