Old 10-01-2003, 02:07 PM   #1
ne_striker
Angry s10 blazer suspention clunks when turning left
My s10 Blazer will make a clunking noise, sort of metal to metal sound.
I've replaced upper control arm bushings, ball joints, all steering componets.
The sound happens when I'm turning left, it is coming from under mid-car
on the right side, seems like right under the passenger seat by the door.
I've check for loose tail pipes...anything that might be knocking into something else and still i can't find anything.
any help please would be much appreciated.
ne_striker is offline   Reply With Quote
Old 11-05-2003, 08:24 PM   #2
nickelbrain
If you have a 4wd there are 2 torsions bars that run under the truck. they connect to bushings about half way back. Change the bushings.
I hade the exact problem and that fixed it. Also when you get the new bushings the one that goes on the passenger side the mounting bolt is a little to long and has to be cut, at least that's what happend to me.
nickelbrain is offline   Reply With Quote
Old 11-26-2003, 06:04 AM   #3
Dean087
Re: s10 blazer suspention clunks when turning left
Take a look at the front body mounts that offsset the body from the frame. They are pretty much under the front floor boards. They rust and collapse and I have seen a few with this problem. There should be several inches of offset, the problem can be hard to detect-compare to any S-10 vehicle.
This is a body shop fix (welding) and can range from $200 to $400.
Dean087 is offline   Reply With Quote
Old 12-03-2003, 02:19 PM   #4
mikeshel
Lightbulb
I had same problem with my 97 Olds Bravada and in this forum found a post back in I belive july that asked the same question and the reply was to tighten the left hand or drivers side hood hinge bolt, it is under the small plastic trim piece remove the trim and tighten the one bolt that holds the hinge to the fender. I tried this and it worked it sounds stupid but it was the best peice of advise I have ever gotten, Thanks to this forum.
mikeshel is offline   Reply With Quote
Old 12-03-2003, 04:36 PM   #5
frankjc
mine does that when turning right...especially if i am turning over a bump i.e., pulling into a driveway.
frankjc is offline   Reply With Quote
Old 12-03-2003, 09:19 PM   #6
frankjc
ok, i figured out why i have this problem.
my blazer needs 4 ball joints, an idler arm, and pitman arm.
gonna cost me about $250 in parts
Old 12-04-2003, 03:43 PM   #7
tspencer73
upper ball joint and or A-arm bushings
tspencer73 is offline   Reply With Quote
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 10:35 PM
Clunk when turning left from a stop - 94 buick century purplegrog Century 4 01-09-2010 08:06 PM
car stalls when turning left persondude44 Engineering/Technical 5 04-16-2009 09:18 AM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 10:11 AM
Steering Clunks when turning left sam_titcombe Fiesta 1 05-01-2005 12:59 AM
