Go Back   Automotive Forums .com Car Chat > Rover > General Discussion
Old 12-28-2003, 09:43 AM   #1
theblob
Rover 620 si abs fault codes
Hi to all.
Maybe someone can help me i have connected the test plug for the abs fault code in the passenger side of the car and i am getting the following code 1 flash of about 1 second duration then a pause also about 1 second duration then 3 consecutive on off flashes which i interpret as a code of 1-3.
But how do i find out what this means my hanes manual make no mention of these codes.
Im having a problem with the abs light coming on after a few mins of driving, it will extinguish if i turn the ignition off and on again but will relight again after a couple of mins.
Abs works fine when the light is unlit but is deactivated while litup.
theblob is offline   Reply With Quote
Old 12-29-2003, 02:48 PM   #2
mechy1barry
Re: Rover 620 si abs fault codes
can you give me,year,and engine code if known,will reply tomorrow
mechy1barry is offline   Reply With Quote
Old 12-29-2003, 03:29 PM   #3
theblob
hi m8 its a 1995 m reg and its the honda 2ltr injection 16valve engine.
the only numbers i can find on the engine are these if they are not what you need let me know and i will have another look.
n254-2036988.
f20z1.
f246759.
Cheers m8
Old 12-29-2003, 03:40 PM   #4
mechy1barry
will let you know tomorrow.
Old 12-29-2003, 03:42 PM   #5
theblob
Thanks m8
Old 12-30-2003, 02:52 PM   #6
mechy1barry
your code(30)relates to e.c.m/transmission control module,(t.c.m)wiring short to earth/open circuit,e.c.m.~if you require code sheet,feel free to email me.
Old 12-30-2003, 02:58 PM   #7
theblob
Thanks for all your help m8.
You have email
ABS fault code C1232 MONTANA 1998 franklin1966 Montana/Montana SV6 0 02-08-2007 12:19 PM
rover 620sli abs fault mike1ryan1 General Discussion 0 02-24-2006 02:54 PM
Rover 620 - Honda 2.0ils - ABS problem richard_cav16 General Discussion 0 07-16-2005 04:33 AM
rover 620 lefthand drive headlights help!!! mat skinner General Discussion 0 04-03-2004 05:07 AM
Rover 620 si Dead spot enizag General Discussion 0 03-03-2004 10:48 AM
